Kubota RTV Facts/Fiction...
/ Kubota RTV Facts/Fiction... #141
I do think experience is the best teacher even in this situation. I have been playing with the machine this weekend. I was thinking the transmission was similar to a car. Put it in drive and go. NOT so. I do not have a owners manual or service manual for the machine so it is trial and error. I am now using the selector more like the manual L,M, and H. Seems to work great. I am also getting better at shifting into the reverse positiion. Going into L range first then into reverse and sometimes using a tip from another post, tapping the excellerator seems to work. I would like to do the neutral position adjustment to see if it makes a difference.
Thanks for the feedback. I appreciate it. I really do like this machine.
Larry:)
/ Kubota RTV Facts/Fiction... #142
Pushing down a little harder on the brake pedal when shifting works wonders on my 500.
/ Kubota RTV Facts/Fiction... #143
Please start a new thread now ... I have an 2011 1140 and can provide info, but it needs to be in a different, unique thread with this focus
/ Kubota RTV Facts/Fiction... #144
welcome mstordahl, i am also new and i have a steering problem listed under atv's and utility vehicles, see if you can help, thanks
/ Kubota RTV Facts/Fiction... #145
The holdback of the machine, both in forward and reverse is controlled by the same relief valve in the transmission. To adjust this, you have to have some good mechanical knowledge and know what to look for. If you feel confident, I will try to help. What I would suggest is since the unit is so new, you should talk to your dealer and have them adjust it for you.
Hey Matt, My name is Danny and I'am new to this forum so hello to you and hello to all who read this!. Anyway I was checking out this thread becuase my 2010 RTV 1100, which I just got has a couple of issues. Ones that I see you address here. 1st the "holdback" or hst braking is a little harsh and I called my dealer to see if they would adjust it. They say the servo can't be adjusted and that the could install a aftermarket coast valve and bypass the HST braking completely. I don't know if I want to do this as I like the braking action , it's just needs to be cut back abit. Has anyone here had the coast valve installed? If so how do they like it? 2nd I have a heck of the time getting the shifter into the"H" postion. It seems not to lock into gear and looks like it's in postion but when the gas is engaged it's still in Neutral. If I pull the pressure relief a couple of times and it helps but still most of the time I have to wiggle it into shifting a few times beofre it will go into gear. Is the cable adjustment you mentioned something that a shadtree mechanic like me could do? Also can or Can't the Trans servo be adjusted and is this something I could do? Maybe with you're help???
Please let me know and Thank you in advance!
-Danny Navarro , Grand Forks ND
/ Kubota RTV Facts/Fiction... #146
on my kubota rtv500, it doesn't go into reverse very easily. have to keep jockeying it a bit before it slips in, how can i adjust this? thanks
/ Kubota RTV Facts/Fiction... #147
par for the machine, try holding the break pedal and wiggling it down
/ Kubota RTV Facts/Fiction... #148
My initial driver's training occurred in a mid 60's Chevy Step-side with a "straight-6" and 3 speeds on the column; my RTV 500 brings back a lot of those (useful) memories that were gained by learning to work with the linkage.
I have also come to appreciate the fact that I have never owned or operated a piece of equipment that met perfect equipment (false) expectations.
/ Kubota RTV Facts/Fiction... #149
Ok just bought a used Kabota 1140 RTV it lacks power to the wheels... What I mean by that is If im in low and start climbing a hill it does not have anymore power at full throttle than at a 1/4 throttle even though the motor revs higher... seems to me like a transmission issue... PLEASE HELP !
/ Kubota RTV Facts/Fiction... #150
I just got a used 1140 as well. It's a 2009 with 715 hours. It seems to have no lack of power to the wheels. Change the hydro fluid using OEM Kubota filters and Super UDT2 oil. Make sure the air filter is clean and clean the spark arrestor, too.
/ Kubota RTV Facts/Fiction... #151
Ok will try... Mine only has 324 hours on it.... Under load or going up a hill mine sounds like its slipping, doesn't matter if I push the pedal to the floor it dogs out before it spins a tire.
/ Kubota RTV Facts/Fiction... #152
The hdyro in the RTV works like a tractor, you need to LET OFF on the pedal to regain speed (letting off is like downshifting in a truck) so if you mash it to the floor it is like trying to climb a hill in high gear. See if that helps.
/ Kubota RTV Facts/Fiction... #153
Again, this is the correct way to use RTV and all HST equipment. You aren't driving a automobile where putting the pedal to the metal gives more power. On the RTV, this one pedal not only increases engine RPM, but also the angle of the swash plate requiring more power to turn it thus stalling the engine if pedal is held down all the way. When climbing a hill, reduce to about half throttle which gives more power to the hydrostatic transmission so it is effectively putting the RTV in a lower gear while not significantly reducing RPMs or speed. I can climb any hill that I have traction for while in M range and never run out of engine power but I do have to back off the throttle.
/ Kubota RTV Facts/Fiction... #154
Correct, that's exactly why I put no stock in the magazine reviews when they compare UTVs, trying to drive the RTV like a car or a regular UTV will skew the reviews away from the RTV. People who don't know how to drive a hydrostat call them a dog every time.
/ Kubota RTV Facts/Fiction... #155
Thank you... I will try that but mine is gutless in M or H.. Mine will slow to a crawl on just a slight incline on a dirt road..
/ Kubota RTV Facts/Fiction... #156
Does anyone know where I can see a diagram of my Kabota 1140's transmission so I know what to adjust... such as the servo
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
10' DISC HARROW (A60430)
10' DISC HARROW...
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
2019 Kenworth T880 Tri-Axle Dump Truck (A59230)
2019 Kenworth T880...
2014 Freightliner 105' Bucket Truck (A61306)
2014 Freightliner...
2022 Ford F-450 Liftmoore 5000W 2.5 Ton Crane Service Truck (A59230)
2022 Ford F-450...
