Clamshell driveway
   / Clamshell driveway #21
We are trying our best to deal with this! IMG_0498.jpgIMG_0500.jpgIMG_0506.jpg
Tommy White is the guy's name, he's a lifetime local and a good guy. Tell him Randy from Airport road sent you.
It's not uncommon for it to take an extra load to load and a half from the estimate, just depends on the base and how wide you do it.
Louisiana, Alabama, Mississippi, Georgia, Florida, south and North Carolina and some in Virginia, the coastal areas are loaded with old shell roads.
   / Clamshell driveway #26
Artist I am not,I just took some crude measurements and heres a picture of where we are getting driveway. Whats your opinion on how many loads it will take? How thick is it generally laid? Was yours done in one day?
   / Clamshell driveway #29
check this website out, lotview.net allows you to mark out an area to measure area.. or you can do just straight lines,
i use it all the time. here's what i came up with using it with your drawing (best i could mimic)
Mine is around 140' by 16' with 2 turnouts one single and a half wide, one two cars plus wide, mine was $2250. I had a good hard base below mine and that helps. He did all the leveling and prep work and had it all but about half a load done in one day.
2012 Ram 2500 4x4 Crew Cab Pickup Truck (A59230)
2012 Ram 2500 4x4...
208735 (A60430)
208735 (A60430)
CASE 610 Sprayer System 2000 Gallons (A56438)
CASE 610 Sprayer...
2022 KOMATSU WA500-8 WHEEL LOADER (A60429)
2022 KOMATSU...
2020 Ford Ecosport 4WD SUV (A59231)
2020 Ford Ecosport...
2015 UTILITY VS2RA 53FT REEFER TRAILER (A59905)
2015 UTILITY VS2RA...
