Will these fence clips pop my tractor tire
   / Will these fence clips pop my tractor tire #22
Yep the 1/8 inch pipe nipple about 5 inches long put it over one end of the tie and untwist it, and it would take about 2 seconds per clip. Easy Peazy.
   / Will these fence clips pop my tractor tire #23
Another idea. Go through and get them tighter on the wire. Then cut them. That way both sides are attached to the wire. After that is done then remove the wire with them attached. If the one end is bent then you can force them down the line and make a spot to grab them all as you roll up the wire.
   / Will these fence clips pop my tractor tire #24
Exactly...clearly T post clips are foreign to some TBNers.
My preferred tool is a small diameter metal pipe...maybe 8 inches long.....it slips over the long protruding clip end and is used to lever the thing loose...also used to apply the clips...
A stout screwdriver shaft can also be used to undo the clips.
You gotta pick them up...time is almost nil, payback large.
You don't even need pliers, a short piece of pipe like a hydraulic jack handle and its off. The time spent doing a write up and reading the replys could have been done, then just wrap wire.
   / Will these fence clips pop my tractor tire #25
You are so right...didn't see your post when I did mine.
   / Will these fence clips pop my tractor tire #26
You cannot undo these with a screwdriver. I think these are homemade from the high tensile wire. They are drastically thicker than others I've dealt with. Even cutting them with smaller bolt cutters is tough.
   / Will these fence clips pop my tractor tire #28
Stick screwdriver shaft in open loop and unwind...kinda pry with it...
I've installed several thousand and removed almost as many...the clip is a standard manufactured clip for barb wire attachment to T post..also works for smooth wire.
small pipe inserted onto the end works best....I use a grease gun extension pipe
   / Will these fence clips pop my tractor tire #29
A hollow shaft nut-driver works well for taking them off.
   / Will these fence clips pop my tractor tire #30
They actually sell a small pipe tool to use for twisting the clips on, but as said, it is just a small piece of tubing that is not nearly as durable as an 1/8" pipe.
That is a good idea about using the grease gun tubing. IF ONLY I could find that tubing I removed from the grease gun when installing my flexible hose.
CATERPILLAR D6R XL CRAWLER DOZER (A51406)
CATERPILLAR D6R XL...
2019 Ford F-350 XL (A50120)
2019 Ford F-350 XL...
2014 Jeep Cherokee SUV (A50324)
2014 Jeep Cherokee...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A52748)
Kubota 24in Quick...
Lull Highlander 1044C-54 Series II 10,000LB 4x4 Rough Terrain Telehandler (A50322)
Lull Highlander...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A52748)
Kuhns AE10 Small...
