Oil tank atv dump trailer
   / Oil tank atv dump trailer #11
You build like I do. Man this will work perfect. Fab it and find out that 'why didn't I see that coming' As Homer would say 'Doh'!
Steve
   / Oil tank atv dump trailer #12
I thought these pictures might be of interest to you.
Wow, that one looks great! Someone spent alot of time on that one. I probably should have used that size just so the radius' would be going lengthwise... oh well. We'll see how this turns out.
I've had a wicked flue for the passed week... so not much progress... and my efin' home computer won't start, so can't put up pics for now.
Ok, so I'm on a couple night shifts... so that means weekdays to work in the garage!
Frame welded to tank
Found a slug for the axle
Wheels sanded, cleaned, and primed
Axle welded and painted as well as the wheels
...and the start of the lower frame
I also cut off the legs and ground smooth. The wheels and tires were mounted today...with inner tubes.
   / Oil tank atv dump trailer #16
Once again great work!
   / Oil tank atv dump trailer #17
So, with my Jeep's dump trailer sold[...]
Aw man, I followed that build and your Jeep dump trailer was sweet! Excellent design and fabrication.
I've been looking at dump trailer designs myself. I really like the T-Rex (also sold as the DR Power Versa Trailer):
ATV Dump & Logging Trailer by T-Rex
When I first looked at their web site it I thought "The crane is stupid, no one will want that." Then I watched their video and I thought "The crane is genius, everyone will want that."
I like the designs that incorporate a mast and a winch to raise the bed. If I recall correctly you used a large jack which worked well but I think using a winch provides some other methods of loading the trailer by dragging things in with the winch.
The MUTS is another design with a mast:
http://www.muts.ca/
Good luck with the new design. I'll be watching.
Oh yes, I did look at all of those... very nice, but rather large $$$.
I could have done the Highlift tilt again, but chose to raise the bed and pivot at the very center for simplicity and cost... and I plan to be able to dump on the move.
Loosely based on this one;
ATV Utility Dump Trailer - Workman by ABI
   / Oil tank atv dump trailer #19
That should be a good design to copy. We have their larger brother the "XL" model.
So what's a good tongue length? As in, distance between atv and trailer. I'm thinking 3'...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2017 Rogator RG1300B Dry Fertilizer Applicator (A56438)
2017 Rogator...
HYDRAULIC WINCH RACK (A58214)
HYDRAULIC WINCH...
2013 Freightliner Bucket Truck (A55973)
2013 Freightliner...
2004 AGCO Gleaner 3000 Corn Header (A56438)
2004 AGCO Gleaner...
FORD 8530 TRACTOR (A58375)
FORD 8530 TRACTOR...
