Have you ever broken the transmission fan on your BX? No or yes will work.
   / Have you ever broken the transmission fan on your BX? No or yes will work. #21
Yes, running a brush hog in the woods with no mmm and no skid plate. I didn't trash it but damaged some of the fins. Fortunately replacing it wasn't as much of a nightmare as I'd read. It was a BX2200.
   / Have you ever broken the transmission fan on your BX? No or yes will work. #22
No.
:D
   / Have you ever broken the transmission fan on your BX? No or yes will work. #23
No. BX2660 and I normally just leave the MMM on for the work around the house.
   / Have you ever broken the transmission fan on your BX? No or yes will work. #24
No- on 2 BX's. Used mostly for mowing and snowblowing, so lower risk machines.
   / Have you ever broken the transmission fan on your BX? No or yes will work. #25
No, but installed BroTek rear and mid plates before use.
   / Have you ever broken the transmission fan on your BX? No or yes will work. #26
Yes and probably the first time I drove it. I bought my BX24 used and the day it was delivered I had to go play in my overgrown field. I joined this list and learned of the vulnerability of the fan and ordered a skid plate before I even discovered that I had broken the fan. Yes, I know I did it because I was able to go out in my field and find the broken blades. On the BX24 and BX25 it is a huge job to replace that fan, much harder than on a BX23. If you ever plan on driving over any scrub brush a skid plate is good insurance.
Yes, replaced and immediately made skid plate, no more problem.
I NOW PERSONALLY KNOW SOMEONE THAT HAS BROKEN THEIR FAN.:)
   / Have you ever broken the transmission fan on your BX? No or yes will work. #29
Not yet but. This our 2nd BX one was a 2200 with 1800 hours and now a 2670 with 25 hours. We are clearing some old fence rows so this is a good place to do damage to a fan.
   / Have you ever broken the transmission fan on your BX? No or yes will work. #30
Yes:smiley_aafz:
And this was after I installed Kubota's so called "fan protector".
I had bush hogged 5 of 7 acres that had not been touched in 50 years. Kept worrying about the hydro fan and always wondering when I would break it. I put the "fan protector" on in the third year of my project, and a stick went between the slots in the plate and wiped all the blades on the hydro fan out.
Kubota dealer replaced it for $261. The mechanic that did the work still throws rocks at me when he sees me. :D
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A51691)
1996 JLG Commander...
2011 Ford Crown Victoria Passenger Car (A51694)
2011 Ford Crown...
2024 Bintelli ActivEV Pulse Electric Golf Cart (A51694)
2024 Bintelli...
2016 Chrysler 200 Limited Sedan (A50324)
2016 Chrysler 200...
Tri-Axle Police Travel Trailer (A51694)
Tri-Axle Police...
