Attempting to save a gasket for reuse- TIPS OR TRICKS?
   / Attempting to save a gasket for reuse- TIPS OR TRICKS? #21
P.S. - if you aren't doing so already, try and use non-ethanol gas in your tractor.
Thats a big 10.4 . As of last year I've started using non ethonal gas in my machines. Costs a little bit more/gal. (about 35 cents) but should be cheap PM.
   / Attempting to save a gasket for reuse- TIPS OR TRICKS? #23
Very low cost PM ! Energy value of pure gas is higher than the E stuff, so the cost per/btu is good.
On pumps that share hoses with E, run at least a gallon into your car, b4 filling gas cans, to flush the pump out.
Rgds, D.
   / Attempting to save a gasket for reuse- TIPS OR TRICKS? #24
got the double-post glitch too just now....
Rgds, D.
   / Attempting to save a gasket for reuse- TIPS OR TRICKS? #25
If you get desperate try looking for a new one. I tried to rebuild my Sears Generator's carb last year with the usual success. Then I started looking on the net using the make and model on the carb body. I found one for $35 on Amazon Prime of all places just like body parts for my truck, whod a thought?. Anyways, I stuck it on and never touched it, worked fine. Ethanol gas is the usual suspect. It just plugs small carbs while it seems fine in the larger ones.
2015 Haulotte 5533A (A53316)
2015 Haulotte...
CAT 312C EXCAVATOR (A58214)
CAT 312C EXCAVATOR...
JLG 20MVL MANLIFT (A58214)
JLG 20MVL MANLIFT...
2014 Chevrolet Express Van (A55973)
2014 Chevrolet...
2019 GALYEAN...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
