Attempting to save a gasket for reuse- TIPS OR TRICKS?
   / Attempting to save a gasket for reuse- TIPS OR TRICKS? #21
P.S. - if you aren't doing so already, try and use non-ethanol gas in your tractor.
Thats a big 10.4 . As of last year I've started using non ethonal gas in my machines. Costs a little bit more/gal. (about 35 cents) but should be cheap PM.
   / Attempting to save a gasket for reuse- TIPS OR TRICKS? #23
Very low cost PM ! Energy value of pure gas is higher than the E stuff, so the cost per/btu is good.
On pumps that share hoses with E, run at least a gallon into your car, b4 filling gas cans, to flush the pump out.
Rgds, D.
   / Attempting to save a gasket for reuse- TIPS OR TRICKS? #24
got the double-post glitch too just now....
Rgds, D.
   / Attempting to save a gasket for reuse- TIPS OR TRICKS? #25
If you get desperate try looking for a new one. I tried to rebuild my Sears Generator's carb last year with the usual success. Then I started looking on the net using the make and model on the carb body. I found one for $35 on Amazon Prime of all places just like body parts for my truck, whod a thought?. Anyways, I stuck it on and never touched it, worked fine. Ethanol gas is the usual suspect. It just plugs small carbs while it seems fine in the larger ones.
Adams Conveyor (A50397)
Adams Conveyor...
1996 Ford F-350 Mason Dump Truck (A48081)
1996 Ford F-350...
2020 Peterbilt 579 Daycab Truck Tractor (A50860)
2020 Peterbilt 579...
2013 Crane Carrier Co. Low Entry Loadmaster Excel-S 25 Yard Rear Loader Garbage Truck (A48081)
2013 Crane Carrier...
2019 FREIGHTLINER CASCADIA DAY CAB (A50505)
2019 FREIGHTLINER...
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
