Have you ever broken the transmission fan on your BX? No or yes will work.
   / Have you ever broken the transmission fan on your BX? No or yes will work. #61
Not yet.
FYI this "Post Reply" requires a message be minimum 5 characters, so yes or no is not an option.
   / Have you ever broken the transmission fan on your BX? No or yes will work. #62
Oh, yes. And replaced it, along with the rubber driveshaft boot. A character-building experience. All that is now armored with 22 ga. galvanized steel.
   / Have you ever broken the transmission fan on your BX? No or yes will work. #63
well, I havent broken it perse'.....I just inherited a BX22 with 1180 hours on it and the HST fan is missing ALL the blades. No clue how long they've been missing but they are. I've bought the replacement fan and plan on repairing it and also getting a skid plate to protect it. This machine doesnt have a MMM but does have FEL and BH.
I wonder how much this little plastic fan cools the HST judging from the number of hours on this tractor and it functions just fine. It may shoot craps tomorrow. I've been around this tractor since it was new and can tell you its been used hard and for more than it was intended.....Kubota has to know this is a weak link on their machines and I wonder why no one has come up with an aftermarket heavy duty metal fan that would chew up the typical small sticks that damage the fan.
   / Have you ever broken the transmission fan on your BX? No or yes will work. #64
Pics?
   / Have you ever broken the transmission fan on your BX? No or yes will work. #65
Yes, and have replaced it 3 times. :smiley_aafz: Did the work myself and yes it is a character building operation. :mischievous: Haven't protected that area yet but take extra care now and all has been fine. Driving over broken branches has been the reason each time. BX2200 purchased new in 2001.
   / Have you ever broken the transmission fan on your BX? No or yes will work. #66
Dang! I can sort of understand not shielding after the first break but are you getting a clue yet? :laughing: I know, not funny.
   / Have you ever broken the transmission fan on your BX? No or yes will work. #67
Dang! I can sort of understand not shielding after the first break but are you getting a clue yet? I know, not funny.
dragoneggs,
There is the right way the wrong way and the TBN way of doing things. :laughing: I chose the TBN way by getting two bigger tractors ( David brown and Kubota L3800) to do the rougher work and now keep the BX2200 strictly for yard work and driveway snow removal. :cool: Problem solved! :thumbsup:
   / Have you ever broken the transmission fan on your BX? No or yes will work. #68
dragoneggs,
I like your solution!!! :thumbsup:
   / Have you ever broken the transmission fan on your BX? No or yes will work. #69
No. I put a Bro-Tek skid plate on when I owned the BX
   / Have you ever broken the transmission fan on your BX? No or yes will work. #70
Two Bx's- Bx2230-No and Current BX2660 No, But is factory guarded and I use a skidplate when mower deck is off.
PENDING SELLER CONFIRMATIONS (A52577)
PENDING SELLER...
2007 IC Corporation PB105 Passenger Bus (A51692)
2007 IC...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A51572)
IMPORTANT PLEASE...
(3) Air Hose Reels (A51573)
(3) Air Hose Reels...
1985 Ford Ltl9000 Tender Truck (A52748)
1985 Ford Ltl9000...
2009 Dodge Ram Utility Pickup Truck, VIN # 3D6WC78L09G558300 (A51572)
2009 Dodge Ram...
