Harbor Freight copies StrongHand Nomad welding table...$59
   / Harbor Freight copies StrongHand Nomad welding table...$59 #51
I use it on mine too. Needs a few big washers to work with the welding table.
I am thinking about making a rectangle type washer, so it only needs a quarter turn or so on the bolt, and the washer turned 90° to remove it quickly when needed.
Very good idea.
   / Harbor Freight copies StrongHand Nomad welding table...$59 #54
You guys might want to check out the StrongHand clamp catalogue too. Much more expensive than the HF stuff but very nicely designed and built. I got a few of them in a starter kit that came with my StrongHand welding table. Don't have any photos but they have a full "professional" range of clamps that is pretty amazing. Might give you some ideas for how to modify other clamps for use on this table.
http://www.stronghandtools.com/stronghandtools/products/kits.php?tab=1#TabbedPanels2
http://www.stronghandtools.com/stronghandtools/index.php
   / Harbor Freight copies StrongHand Nomad welding table...$59 #56
I picked up one of these tables on Saturday. The cashier was surprised that they had one in stock, I guess I got lucky seeing it was wedged between some other items kinda hidden. Seems to be built pretty well. The instructions are crappy, I had to flip between pages and measure bolt lengths. Somehow I ended up with extra parts...lol. I also had an issue with one of the yellow plastic handles. As the bolt pulled into the handle it got to a point where it spun because it was round deep inside instead of hexagonal. A bit of solid wire around the bolt to space it back farther into the handle fixed that for now. The table plus 2 magnetic 90 degree stock holders for $52. Can't complain about that.
   / Harbor Freight copies StrongHand Nomad welding table...$59 #57
I checked every HF within 50 miles of my home....nobody had any in stock. I had to go to Florida to deal with some family business last week and found a HF about 2 miles from my mother's house. They had 3 in stock. I bought mine and trucked it back home under the luggage in the back of my car.
   / Harbor Freight copies StrongHand Nomad welding table...$59 #58
My plastic handles were worthless. The welded nut on the inside of the legs was welded at a slight angle on both sides. so the machine screw bound slightly do to the friction caused by rubbing on the os of the hole on the other side of the leg. The plastic handles both spun right around the head of the bolt. I guess I have my first welding project on the table.
Given HF, that was predictable.
John Deere 652R 52in Stand-On Commercial Mower (A56857)
John Deere 652R...
2021 Billy Goat F902H Walk-Behind Debris Blower (A59228)
2021 Billy Goat...
2022 John Deere 4052M MFWD Compact Utility Tractor with 400E loader - Bucket, Forks and Grapple (A55314)
2022 John Deere...
2019 Peterbilt 520 Heil Side Loader Garbage Truck (A55973)
2019 Peterbilt 520...
SKID STEER ATTACHMENT SIFT BUCKET (A58214)
SKID STEER...
2019 CHEVROLET SILVERADO LD CREW CAB TRUCK (A59823)
2019 CHEVROLET...
