Sizing Generator for Submersible Well Pump
   / Sizing Generator for Submersible Well Pump
Howdy,
At least you have taken the correct steps to figure things out. Researching the manufacturers recommendations is a important part. Yes, I would say that your control box has the added wizardry for soft start. When someone talks about a 5hp motor on a farm, it is a good size load for starting and running. Since you say its for irrigation, you then have tractors as well. Since this is all wired into your system, you will need to think about how it will all connect into your panel. Some questions below.
1. what is your service? type? (pole top, underground, separate meters)
2. distance from panel to this pump control box? Do you have a smaller panel in your pump house?
3. how many times do you lose power?
4. do you have any other wells on the farm?
5. besides powering the well, what other power things do you want to run? do you want to run it all at the same time? or run the 5hp pump, then shut that breaker off and run everything else?
self contained mounted genset system, open inside genset system, pto generator system?
My "farm" is just as a hobby. About 60 fruit trees, some blueberries and raspberries, lawn sprinkling and a big garden. Everything runs off of the one well which is wired into the house electrical panel. I don't lose power much and can run what I need on a small generator; except for the water well (I think, haven't tried yet). That gets old in a hurry with five kids, though. I plan on filling the pressure tank and then shutting off the well. I don't need the whole house powered and am content to flip some breakers to save money on a larger genny. If have to go bigger than my 7,500W continuous 9,500W peak portable unit; then I probably will get a PTO unit for the JD.
   / Sizing Generator for Submersible Well Pump #13
There is something odd going on with that 30amp breaker. There is no way a working 30amp breaker won't trip starting a well pump of that size. With just a standard across the line starter.
That breaker is likely failed internally and is offering no protection. The main electrical service breaker maybe the only short circuit protection to the pump.
It's cheap insurance to obtain and install a new 70amp breaker that works.
I snagged a new Franklin VFD box cheap on ebay for my well pump but alas. The box is for a three wire pump and the cheapskate that installed the well used a two wire pump.
   / Sizing Generator for Submersible Well Pump #14
maybe tackle this from another angle .... how deep is it to the water table ? how big is the well casing ?
you may be able to drop a jet pump injector and smaller lines down beside the existing pipe and use a much smaller 1/2 or 3/4 HP pump to get water as a backup system to refill the water tank, and using a smaller generator .... yes it will take longer to "fill and pressurize" but at least you have water and it won't take specialty equipment..... $$$$$$
   / Sizing Generator for Submersible Well Pump #15
Are you positive it's 5hp? You must be getting unbelievable gpm/pressure. With that power, you must be filling your pressure tank in seconds.
If you already have a gen, why not give it a try? I would like to do the same so I'm also interested in what you find out.
   / Sizing Generator for Submersible Well Pump #16
   / Sizing Generator for Submersible Well Pump #17
There is a real possibility that the well has a 5HP couple coupled to a 3HP motor. That could explain the 5HP starter and the motor operating from a 30 amp breaker.
For motors with thermal protection such as this pump. The breaker's only role is to interrupt short circuit events.
I have a 3HP 15FLA 240V Campbell and Hausfeld air compressor. A compressor rated motor with large starting cap and a compressor unloader. I tried plugging it into a 12/2 20amp 240V supply for the heater in the garage just out of curiosity. To my surprise it has operated for years ( without the heater) and has never tripped the breaker ?
One of these days when I get around to installing a breaker panel with more circuits. There will be a pony panel also installed in the garage to supply some dedicated tool receptacles.
   / Sizing Generator for Submersible Well Pump #18
I have a 3/4 hp well pump 260 feet deep. Also a 18 KW whole house gen set. I know from sound of gen set starting the pump is a pretty good sized load. Only other load you can actually hear is AC system.
Here is the chart from Franklin. Google Franklin AIM manual page 5.
Page 5 | AIM Manual | Franklin Electric
Hi Goose. That was the manual that I found online as well. It says 7,500W internally regulated and 15,000W externally regulated. Guess I need to do some research on that, since I don't know what the difference is. I've also got a call into Franklin.
Yep, its a 5HP. I need the GPM for irrigation, and, yes, it does fill the pressure tank pretty quickly; but it doesn't cycle the pump enough to be detrimental to the motor. Once I get more info, I may try my 7,500W, 9,500W peak unit.
2001 New Holland EC215 Hydraulic Excavator (A52377)
2001 New Holland...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
2016 KENWORTH T270 SERVICE TRUCK (A51406)
2016 KENWORTH T270...
2020 VANGUARD CIMC 53FT REEFER TRAILER (A54607)
2020 VANGUARD CIMC...
2009 Kaufman Gooseneck Trailer and 10K Hydro-Blast (A50860)
2009 Kaufman...
