Digging Pond questions
   / Digging Pond questions #11
That sounds like a very small pond. I did some calculations and assuming very steep 1:1 slope for the sides, thats only about 600 yards of dirt and even less if the sides shallow out a bit.
   / Digging Pond questions #12
I'm thinking when he gets down to doing it and sees the slope, he'll revise his size. My first, smaller pond has 1/1 slope on one side and it's kinda ugly looking when water level is way down. 2/1 slope is iffy mowing with my zero turn mower on the other side and dam.
My second pond has 3/1 slope down to 7 feet, then drops off to 11 feet.
hugs, Brandi
   / Digging Pond questions #14
Agree on soil test first. Even with clay as mine, it may take several years of silt for it to really become functional which mine did require. My main problem even with clay and all was that it's cut into the side of a hill where the dam outer perimeter was some 10' below spillway. At 1/2# per foot of elevation, that's only 5 psi of water pressure against the soil, but it doesn't take much to work it's way through it.
On volume, you said 13 acres in your place. What you need to know is the size of the watershed then multiply by the anticipated rainfall to get an acre-feet number. Apply that to your acre-feet or whatever measurement reference you choose for pond size and you will have the answer to your question. Course like we have had this past winter and spring, I got lots of rain, but it was spaced out and slow in falling and all soaked in....pond got only what fell on it. Ground has to get saturated and then rain must fall at a rate that will produce runoff and then the acre-ft of watershed can apply......per my experience here over the last 35 years.
HTH,
Mark
   / Digging Pond questions #15
Where is the water table?
Where we used to live, the water table was an inch under the surface in winter, 6' deep in a serious drought year. As such, we had good success. With yours being a wet area, you might have the same situation, depending on why it's wet.
no elevation change.....
yeah the acres im referring to is 6 inches wide and 33 miles long cause that's normal....maybe it is in ohio.....really come man
square acres
either way im going to attempt the pond.....digging the pond is just something im going to do after I clear my land because that's the main reason im getting dozer.....plus I need some dirt to level out some areas and build drive way up.
I can always come back later and dig out the" started pond" with back hoe
   / Digging Pond questions #18
square acre.... now that's something new to me.
i hope the google can be of help.
   / Digging Pond questions #19
square acres
No way for us to know otherwise. It certainly aint an ohio thing I dont think. Maybe its a texas thing to refer to distance measurement by using a measurement of area?
Either way, not trying to tell you not to dig the pond. Just trying to say you will likely need to adjust your dimensions of the pond cause I think you will have issues with a dozer pushing up them slopes.
   / Digging Pond questions #20
Meadow2014. Just start digging and have fun. You'll find, from time to time, replies to your thread that in no way help what you are asking and are planning to do.
hugs, Brandi
2008 Ford F-450 Knapheide Service Truck (A55788)
2008 Ford F-450...
2016 CATERPILLAR 313FL EXCAVATOR (A52705)
2016 CATERPILLAR...
2019 Kia Soul SUV (A53424)
2019 Kia Soul SUV...
(INOP) 2016 AUTOCAR EXPEDITOR GARBAGE TRUCK (A51406)
(INOP) 2016...
2012 CATERPILLAR D5K2 LGP CRAWLER DOZER (A52705)
2012 CATERPILLAR...
HEAVY DUTY 7' X 13' X 3.5' WAREHOUSE STORAGE SHELF (A54756)
HEAVY DUTY 7' X...
