3-Point Hitch Mower hitting JD 4105 tires in transport
   / Mower hitting JD 4105 tires in transport #12
From correct operating pressure to 6-10#s as you suggest would be very small % in diameter reduction!
Find a 14.9X24 and measure dia at 6,12,18,24 and 32 psi. The center of the tire in particular bellies out at high pressure. The poster has not stated either if this is a light rub or the rotarty cutter is jammed hard into the lugs.
I don't know why the poster just wouldn't limit the lift height of the rockshaft control handle?
   / Mower hitting JD 4105 tires in transport #14
Any tire will swell with more pressure, but I have owned 14.9X24 tires, and they do not swell that much, Certainly nowhere near enough to interfere with a rear mounted implement of any kind, even when inflated to max pressure.
   / Mower hitting JD 4105 tires in transport #15
Sorry b&d you made the statement so you'll have to conduct you're own measuring but I really think it's a waste of time. Why would anyone desire to operate a tractor with 24-32# in the rear tire exceeding manufacturers spec's?
   / Mower hitting JD 4105 tires in transport #16
The fellow is new to the tractor and possible tractor operation. It would not be the first time a tractor operator , tire shop or dealership. Aired up all the tires to max rating on the sidewall. As if they were filling car tires.
2021 CASE IH 345 (A53084)
2021 CASE IH 345...
Kenmore KLFC015MWD0 Deep Freezer (A53117)
Kenmore...
UNUSED RAYTREE RMBD72S-72" DRUM MULCHER (A51248)
UNUSED RAYTREE...
2018 HONDA RECON 250 4-WHEELER (A51247)
2018 HONDA RECON...
UNUSED FUTURE BOX OF MISC RATCHET STRAPS (A51247)
UNUSED FUTURE BOX...
2016 John Deere 7210R MFWD Tractor (A53342)
2016 John Deere...
