How would you go about recommissioning a diesel that has been idle for eight years?
   / How would you go about recommissioning a diesel that has been idle for eight years? #13
I usually make a couple of revolutions by hand just to make sure nothing is in the cylinders. I have had more than once on stored engines a cyl with water, mouse nests, nuts you name it. The water is the bad one, if the engine hits on any of the other cyls it can bend or break a rod. Sounds like you have the rest covered, I would not sweat the old fuel in the injection lines/injectors as long as it is fuel and not water/crud it will be gone quickly. Have fun!
I've already turned it over by rotating the pulley that drives the alternator etc so I think I'm covered on that front. Mostly anxious about the fuel but as the fuel left in the lines has already run through the Racor (albeit 8 years ago), I suppose it should be OK. There was no problem with the fuel when I stopped using it but I'm sure condensation and ?bio contaminants have screwed up the fuel in the tank. I intend to drain and disassemble the tank for cleaning (luckily it is on deck level just behind a simple panel) so I can get rid of that easily enough.
Heavy Duty Excavator Ripper (Fits CAT 305) (New/Unused) (A59225)
Heavy Duty...
CABINET OF HOSE ENDS (A58214)
CABINET OF HOSE...
2009 INTERNATIONAL 9200I TANDEM AXLE WRECKER (A58018)
2009 INTERNATIONAL...
(2) HOT FUDGE DISPENSERS (A58374)
(2) HOT FUDGE...
2019 F150 (A56435)
2019 F150 (A56435)
2004 John Deere 310G 4x4 Loader Backhoe (A56857)
2004 John Deere...
