Everlast PA300 Rookie
   / Everlast PA300 Rookie
That is a very nice cart!:thumbsup:
How you like that husky chainsaw? I have two of them. :cool:
Thanks ShieldArc;
Love it, starts with 2 pulls cold & 1 pull warm every time. 455 rancher with 20" bar. Been using it a lot the last 2 weeks clearing for a new driveway, and hauling the logs away with the tractor.
   / Everlast PA300 Rookie #32
I don't use my chainsaws hardly at all anymore. I have all my clearing done. But every once in awhile a tree will fall, and I have to buck it up, and give the one neighbor lady the fire wood. I need to take my 350 in it's getting hard to start when cold. I used a husky years ago on the job, I really like the chain speed, and light weight.:cool:
   / Everlast PA300 Rookie #33
Start and run your two strokes about once a month or so. It keeps the carb going well. I've found 5 minutes of running every two months saves 30 minutes of frustrating carb cleaning.
   / Everlast PA300 Rookie #34
If you ethanol fuels. Run them dry and refuel with fresh fuel when you need it. Ethanol plays havoc with the fuel line, impulse line, crank seals and carb boots. SA sell that 460 and use the money to send the 350 to Tn. It will out run and outlast that 460.
   / Everlast PA300 Rookie #35
I almost bought a cart over the weekend, then I ran the wire and worked my arse off doing it.
I put a 50 amp circuit in a very good location, and will build a wood bench there, and when I need to move to the work piece I will use welding lead.
I decided not to use the OLD 50 amp outlet and plug that I had, instead I ordered a 6-50R&P from Graingers today.
It will be in tomorrow
   / Everlast PA300 Rookie #36
HEY, HEY, HEY!!! I can finally beat His Majesty (aka Shield Arc) at something.:D
>Husqvarna 338 XPT
>Husqvarna 345e
>Husqvarna 51
>Husqvarna 372XPW
and
>Stihl MS361
>Echo 355 CS 355T
>McCulloch EB/Mac100
>McCulloch EB/Mac 2010
>Poulan 2150
>Homelite XL/Super 2
>McCulloch ProMac 850
>and a Sears model ?
(truth be told, the last 6 saws are junk)
But I give up on the welders.:confused3: The PA 300 is probably my last.
   / Everlast PA300 Rookie #37
Wired on the plug last night, plugged the PA300 in and looked at the display. When i wired in the receptacle I put it high on the wall where little fingers (grandson) couldn't get to it. I also put it upside down by accident so the cord comes off toward the ceiling, so i turned that over as long as I was wired.
I am going to run a bead this weekend (if the rain stops) but have a confession, a compliment, & a question. First the confession, it's been a couple few years since I've welded. In my day I eventually was able to make clean hot welds and was even tapped to fill in for the full time welder whenever he took leave. But I really only did was I was told, i.e. "For this steel use this rod & set the dial here, for that steel use that rod and set the dial there..." IOW, I didn't have to think to weld.
Now the compliment: The advice here has been awesome and I think I can pick the right rod for some basic work and have an idea where to set the dial to start. We'll see!
My question, I remember that welding galvanized anything is a no go, there may be specialized set-ups or safety precautions that make it doable, I don't know. What about plated nuts, bolts, washers, etc...? You know, the garden variety hardware you pick up out of the bulk bins at the store. Is it okay to weld these, or should I seek out the non plated variety?
Yeah, I got two Husqvarnas if that helps ;)
You are gonna like this machine! I hadn't welded in 30 yrs and with the starting points the guys here gave me I turned mine on, struck an arc 1st try and burned a whole rod. With just a little more practice I'll be ready to build something!! :cool2:
   / Everlast PA300 Rookie #40
this calculator by Miller might be of some help to you.
I spent years welding galvanized structural steel, just set up a small fan to blow the smoke away from your face.
...and thus the compliment!
Thanks! That is very helpful.
2021 Cat D5 LGP Dozer (RIDE AND DRIVE) (A50774)
2021 Cat D5 LGP...
3pt Ditcher (A50121)
1998 CATERPILLAR 120H MOTORGRADER (A51406)
1998 CATERPILLAR...
2015 JCB 930 6,000lbs 4x4 Rough Terrain Forklift (A50322)
2015 JCB 930...
Chery 2 Post Car Lift (A50121)
Chery 2 Post Car...
2011 Manac 36245B30 45ft T/A Walking Floor Trailer (A50323)
2011 Manac...
