Build your own European/triangle/delta hitch
   / Build your own European/triangle/delta hitch #2
Its called the Accord system, named after the airseeder company that invented it. (now Kverneland)
   / Build your own European/triangle/delta hitch #4
The delta hook wont last a day pushing dirt with either of my tractors..
   / Build your own European/triangle/delta hitch #5
Subscribed. A accord style hitch is on my to-build list.
I also like the new ones from Gangl Gangl Docking Systems
   / Build your own European/triangle/delta hitch #6
I built one patterned after a jiffy hitch using 2 inch square tubing with 1/4 wall thickness, and welded a piece of 3/16 x 2 flatbar to the face of it so it matches up with 3 inch ship channel for the implement side. the nice thing about the way the jiffy hitch is made, is it incorporates a 2 inch receiver tube in the design so you can just put a trailer hitch in the tube and go. I will post pictures of mine soon.
   / Build your own European/triangle/delta hitch #7
What can a Delta hitch do that a $79 hitch from HF not do??
   / Build your own European/triangle/delta hitch #8
   / Build your own European/triangle/delta hitch #10
According to the video, it connects the PTO and hydraulics too, so you can swap everything without leaving the seat...?
   / Build your own European/triangle/delta hitch #11
I built my hitch for the tractor and 4 implements for around $200. I really like the self aligning of the hitch, if you get anywhere close to lined up it will connect. also I think my hitch keeps the attachments closer to the tractor which is important on small tractors.
   / Build your own European/triangle/delta hitch #12
pictures of my home made jiffy hitch. I also included a pic of the ship channel, it has much longer sides than regular channel iron.
2011 Chevrolet Impala Sedan (A59231)
2011 Chevrolet...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A59575)
2020 INTERNATIONAL...
2011 Ford Escape SUV (A59231)
2011 Ford Escape...
Case 1083 20ft Corn Head (A56438)
Case 1083 20ft...
2024 CATERPILLAR 305 CR EXCAVATOR (A60429)
2024 CATERPILLAR...
2012 DIAMOND C  40FT GOOSENECK TRAILER (A58214)
2012 DIAMOND C...
