Build your own European/triangle/delta hitch
   / Build your own European/triangle/delta hitch #2
Its called the Accord system, named after the airseeder company that invented it. (now Kverneland)
   / Build your own European/triangle/delta hitch #4
The delta hook wont last a day pushing dirt with either of my tractors..
   / Build your own European/triangle/delta hitch #5
Subscribed. A accord style hitch is on my to-build list.
I also like the new ones from Gangl Gangl Docking Systems
   / Build your own European/triangle/delta hitch #6
I built one patterned after a jiffy hitch using 2 inch square tubing with 1/4 wall thickness, and welded a piece of 3/16 x 2 flatbar to the face of it so it matches up with 3 inch ship channel for the implement side. the nice thing about the way the jiffy hitch is made, is it incorporates a 2 inch receiver tube in the design so you can just put a trailer hitch in the tube and go. I will post pictures of mine soon.
   / Build your own European/triangle/delta hitch #7
What can a Delta hitch do that a $79 hitch from HF not do??
   / Build your own European/triangle/delta hitch #8
   / Build your own European/triangle/delta hitch #10
According to the video, it connects the PTO and hydraulics too, so you can swap everything without leaving the seat...?
   / Build your own European/triangle/delta hitch #11
I built my hitch for the tractor and 4 implements for around $200. I really like the self aligning of the hitch, if you get anywhere close to lined up it will connect. also I think my hitch keeps the attachments closer to the tractor which is important on small tractors.
   / Build your own European/triangle/delta hitch #12
pictures of my home made jiffy hitch. I also included a pic of the ship channel, it has much longer sides than regular channel iron.
2014 Dodge Charger Sedan (A59231)
2014 Dodge Charger...
2022 BOBCAT MT100 STAND-ON SKID STEER (A60429)
2022 BOBCAT MT100...
2001 John Deere 6210 (A60462)
2001 John Deere...
2014 Chevrolet Express 3500 Cargo Van (A55852)
2014 Chevrolet...
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A59231)
2014 Glasstream...
Bobcat 435 FastTrack (A60462)
Bobcat 435...
