Lubricating proof meter cable?
   / Lubricating proof meter cable? #21
Can't do much for $50, but I have "reworked" the tachometer on my "I-talian" motor bike. Spent some time with the input driven by the lathe after confirming spindle RPM with a rpm-o-meter ;-)
Those little eddy current cups inside need to balance the pointer against a light spring. some what fiddly, everything needs to be clean and lubed.
$50 is not bad for a new one unless you enjoy the work (I do ;-)
if you can get all those hours in in 6 months you might be ok. because that's about the lifespan of some of the new proofmeters! :)
Really? Wow, I guess that goes to show that things just aren't made the way they use to be....
   / Lubricating proof meter cable? #23
YEs
It's a conspiracy by the used equipment dealers to destroy all indication of actual use and condition of anything they try to pedal on the unaware.
I hear Krylon and Rust-O-leum are in on it too!
   / Lubricating proof meter cable? #24
So is there any one part of the new meters that is more succeptable to failure, and that a little extra maintenance could prevent it, or is it just the whole thing in general?
   / Lubricating proof meter cable? #26
some report the hours failing and the tach continuing to work
Well I have an update on the meter and cable installation. I haven't had much seat time since the install 8.3 hours to be exact according to the meter. That's all it took to twist this cable in two. The meter is still good and turns freely. Below is a picture of how well the cable handled those few hours. What a joke, I wish I remembered what brand the cable was. image.jpgimage.jpg
UNUSED HURRICANE STAND ON SKID STEER (A52706)
UNUSED HURRICANE...
2014 Ford Taurus AWD Sedan (A51694)
2014 Ford Taurus...
2021 JOHN DEERE 648LB SKIDDER (A51406)
2021 JOHN DEERE...
2014 Triple Crown 10ft S/A Utility Trailer (A51694)
2014 Triple Crown...
Honda Pressure Washer (A53117)
Honda Pressure...
2025 IR UNUSED Cleanout Bucket (A53117)
2025 IR UNUSED...
