Ford 4000 Owner with PTO and Lift arm problems
   / Ford 4000 Owner with PTO and Lift arm problems #11
   / Ford 4000 Owner with PTO and Lift arm problems #13
for the life of me don't know how i missed the 63-64 in his very first post.
DOH! my bad!
For the record, it is a 64. I completely removed the hydraulic cover, replaced all o-rings, gaskets, etc. Honed the large cylinder and replaced both rings on the piston, cleaned up all the "moveable parts" put it back together, primed the pump and still no movement of the arms at all. The PTO still can be stopped by hand. I am beginning to think that the lines themselves are the problem. Keep in mind, this thing was full of water and sat in an open shed for many years without moving. I am wondering if the lines possibly froze and cracked open. Anyone know anything about that? I sure could use some help with it. Thanks.
   / Ford 4000 Owner with PTO and Lift arm problems #16
the pto issue is perplexing unless it is sos.
on the hyd lift..have you checked for fluid flow at the option cover on the top cover?
   / Ford 4000 Owner with PTO and Lift arm problems #17
When you had the lift cover off, did you remove the unload valve plug and make sure the unload valve wasn't stuck?
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2012 CATERPILLAR 304E CR EXCAVATOR (A51242)
2012 CATERPILLAR...
2009 KUBOTA M7040 TRACTOR (A51406)
2009 KUBOTA M7040...
2023 UNVERFERTH 632 LOT NUMBER 179 (A53084)
2023 UNVERFERTH...
2018 AMERICAN HAULER (A52576)
2018 AMERICAN...
Manac Walking Floor Trailer (A50322)
Manac Walking...
