Ford 4000 Owner with PTO and Lift arm problems
   / Ford 4000 Owner with PTO and Lift arm problems #11
   / Ford 4000 Owner with PTO and Lift arm problems #13
for the life of me don't know how i missed the 63-64 in his very first post.
DOH! my bad!
For the record, it is a 64. I completely removed the hydraulic cover, replaced all o-rings, gaskets, etc. Honed the large cylinder and replaced both rings on the piston, cleaned up all the "moveable parts" put it back together, primed the pump and still no movement of the arms at all. The PTO still can be stopped by hand. I am beginning to think that the lines themselves are the problem. Keep in mind, this thing was full of water and sat in an open shed for many years without moving. I am wondering if the lines possibly froze and cracked open. Anyone know anything about that? I sure could use some help with it. Thanks.
   / Ford 4000 Owner with PTO and Lift arm problems #16
the pto issue is perplexing unless it is sos.
on the hyd lift..have you checked for fluid flow at the option cover on the top cover?
   / Ford 4000 Owner with PTO and Lift arm problems #17
When you had the lift cover off, did you remove the unload valve plug and make sure the unload valve wasn't stuck?
2018 Club Car Carryall 1700 (A51573)
2018 Club Car...
2021 Redirective Crash Cushion Guardrail (A51692)
2021 Redirective...
2015 CATERPILLAR 323FL EXCAVATOR (A51246)
2015 CATERPILLAR...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
2019 RBR Venturi 380 (A53472)
2019 RBR Venturi...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
