ultrarunner
Epic Contributor
- Joined
- Apr 6, 2004
- Messages
- 24,566
- Tractor
- Cat D3, Deere 110 TLB, Kubota BX23 and L3800 and RTV900 with restored 1948 Deere M, 1949 Farmall Cub, 1953 Ford Jubliee and 1957 Ford 740 Row Crop, Craftsman Mower, Deere 350C Dozer 50 assorted vehicles from 1905 to 2006
Looking for suggestions on the best material to replace 1500' of galvanized water line dating from 1940.
The old water line is on borrowed time and requires patching yearly.
The ground is expansive adobe and in earth quake country. It is in California and freezing is not an issue.
The line supplies drinking water from a spring several hundred feet above to a 2,000 gallon water tank which is about 60' higher than the homestead.
Years ago, I helped someone run a "Rubber" type line about a 1000 feet long in snow country... it was one continuous run and the coupling on each end was a slip fit over the ends of the rubber hose held in place by the water pressure expanding the hose against a ring of what looked like nail points to lock the coupling to the hose.
