Welding 3/16" & 1/4" with 120v wire-feed
   / Welding 3/16" & 1/4" with 120v wire-feed #131
ok Play nice so we can all get back to learning something. Vent all the poisons fumes so it is out of everyones system. I like this site and have not been on for almost 2 years because of the senseless squabbles on the tractor side. I am trying to learn welding and value everyones opinion.
You're right it doesn't need to be like this. Will try something different.
   / Welding 3/16" & 1/4" with 120v wire-feed #133
Nicely done Furu... thanks for sharing. I'm taking a 'break' from this banter and visiting my incredible 84 year old aunt in Oslo as I write. Perspectives change when scenery is swapped.
Maybe I will post a tiny weld project that her very old neighbor friend just finished for her that put a huge smile on her face. I hope you all are smiling too appreciating the gifts and sharing of life.
I don't feel the need to "yap" about a project unless there is a benefit that I feel can be gained by others.
Furu - AMEN! Well put.
Exactly my intent for creating this thread, so TBN members can see what a 120v MIG can do. The subject is "Welding 3/16" & 1/4" with 120v wire-feed".
I think members are interested in your projects, especially one-off. That's why people buy welders, they want to make stuff that they can't buy. Your stuff merits its own thread, not buried off-topic on page 14. Why do you need to hide your stuff? Are you afraid of something? You could make a thread and call it "One-off stick-weld projects" and it would be popular (and on-topic). It's EXACTLY what members want to see.
Furu I do not understand why you need to spin what I do. You write well, carefully, and members seem to accept your spin over what I write. I am SIMPLY showing examples of what a 120v MIG can do for the express reason that, if someone searches for "120v MIG" I think the member wants to see examples, wants to know if the 120v welder is a useful machine.
As it is now a search on TBN can only return replies posted by members who do NOT HAVE A 120v MIG. This is a regrettable situation. I can't really understand why this is happening, and it does not serve forum members well.
Furu - AMEN! Well put. I don't see anything going on here but personal insults from a guy that seems to loathe people that help others.
ThomasH, you are mistaken. I'm trying to help others, but the thread is being driven off-topic with a vengeance. Most of the 14 pages is personal insults from (in your words) guys that loathe 120v MIGs.
   / Welding 3/16" & 1/4" with 120v wire-feed #135
While it is useful to know what a 120v MIG can do, it is also important to note its limitations as weldermike pointed out:
You can work a small machine past its capabilities no doubt, ive done it in the past, but it comes with experience. Smaller wire, pre heating, beveling, open roots etc, the reason we argue the fact constantly is people get a false positive of the capabilities of there machine. Alot of people just buy a machine and jump on the first bit of advise that suits there needs and they are off to the races with the "thats exactly what i wanted to hear" advise. Factory welds on most shlt are garbage for sure, but they are usually undercut and sloppy. Heres the differance between both. Undercut and sloppy means the equipment comes home still hanging. Cold lap means shlt is gone, on the highway, in a field, on someones head, or breaks off the back of a atv going up hill and crashes into your son with a pole saw hanging out of it that was following you. They serve a purpose no doubt, but just not for what most people believe. Dont be so quick on judging comments or advise.
Actually, it doesn't return such posts because most posters haven't made a point of the fact that they are using a 120v mig in the title. My RTV trailer was built with a 120v mig: http://www.tractorbynet.com/forums/welding/270953-trailer-build-my-first-real.html and http://www.tractorbynet.com/forums/projects/270309-new-woods-trailer-our-rtv.html
Loath? I suspect that its more along the lines of they:
1. Have the experience to be able to look at a weld and say "that has flaw x in it" (which experience they gained from years of welding and in some cases, years of xray quality welds that had to be right the first time)
2. Know that its easy to reach (or pass) the limits of a 120v mig and have a bad weld that looks good
3. Have seen enough people buy a 120v mig, do welds that don't penetrate and then have it break that they want to help people fix their flaws when they are learning before they get bad welding habits
4. Know that if you trip the duty cycle in the middle of a weld where your machine is maxed out, you will have a hard time getting it warmed back up enough to have a good transition for your restart
Personally, I used a couple of borrowed 120v migs (a Craftsman 135 amp and a Millermatic 211 running on 120v) to build my RTV trailer, they worked very well (hit the duty cycle a few times though and popped the breaker a few more times), but I had a couple of "pretty" welds (on the stake pockets, welding the 3/16 pockets to the thinner frame) that didn't hold up. I am currently learning how to weld with a 220v stick welder that I inherited and the difference is amazing. Yes, its harder to get it started, but it easily does in one pass what the 120v took 2+ passes to do.
Would I like a 120v or 220v mig? Sure, it would be very nice but for now my free 220v stick machine does what I need it to do.
Aaron Z
Aaron, you quoted Weldermike, who provided perhaps the only useful "experience" in this whole 14 pages. I should have picked up on it sooner but was de-railed by his F-bombs. Ooops, I need to read better between the lines.
Well said Mike. This is exactly what people with 120v welders need to know, and need help with. I have never considered smaller wire as a way to solve some of the problems but seems it might help allowing more time for heat to build up. Is that how it works?
Often a job is entirely below 1/4" with just a couple inches of weld exceeding 1/4". It can be many times stronger than stick-poop that they will do, especially when they think a stick-welder solves every problem 120v MIG poses. They really do believe a tick-welder is the simple answer, don't you think that's could be more dangerous? Beveling, preheating, there are many easy options and basically intelligent people can learn these tricks, they are useful with thicker material projects (in the future). I saw a trailer hitch on a van a month ago that was just a pile of welding berries mixed with slag.
I understand what you are saying, but disagree in the course taken. There will be problems always but there will be much much more success. I request to teach them how to do it, and how to find the true limits rather than exaggerate the low side. You don't think they can handle it, will get all crazy and try to weld the space shuttle? Probably not. They have small projects. Only a fool would buy a 120v for large projects, it says the limits right on the outside of the BOX! This fool would have the same (or more) problems with a 220v MIG or a perhaps worse with a stick welder.
There are so many projects that members can do, learning that are so well-within the capabilities of a 120v welder. 120v tops out around 1/4". Beginners, for safety, should probably not weld bigger, heavier projects which have larger possibility of causing bigger heavier problems. Many many projects, especially learning projects, are at 1/4" or below.
Mike your final paragraph is "quick judge advice". Do you trust members repeating this "advice" without really understanding it, more than you trust them to actively LEARN how to use a 120v welder?
   / Welding 3/16" & 1/4" with 120v wire-feed #137
Sodo - you attack people you say you agree with while you compliment them.
That boils down to not actually agreeing with them.
Just my .02
Dave I agree with some of the points, disagree with other points, and was pleased to uncover some actual "on-topic experience". I was pleased that weldermike let some slip out but disappointed that he quickly tried to cover it over.
This is a discussion. Not clear what's the purpose of your $.02 but if you have anything useful to add it would be appreciated.
I recall you mentioned having trouble using a 120v with flux core wire. I tried flux core once on a friend's welder (for just a few minutes) and was not impressed, did not investigate further. It was a nice welder, a Hobart. I think he concluded that he will never learn to weld. He bought a good welder but stopped short of adding the gas. If it had AR/CO2 gas I could have impressed this newbie. I have never since tried flux-core again, can't say more about it than I have already written here.
   / Welding 3/16" & 1/4" with 120v wire-feed #139
I built my ballast barrel with 1/4" thick steel using my 135 Handler. It's about 1/2 ton and hasn't fallen apart. Certainly a professional welder using a better machine could have done a better job. I don't know how I'd measure the benefit of that though since again it hasn't fallen apart.
   / Welding 3/16" & 1/4" with 120v wire-feed #140
Must be thinking of a different guy, don't remember commenting on flux core?
I don't use flux core much - prefer stick if I'm going that route.
74in FEL HD Round Back Bucket (A52748)
74in FEL HD Round...
HYUNDAI 30D-9 STRAIGHT MAST FORKLIFT (A51246)
HYUNDAI 30D-9...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
JOHN DEERE 5125R (A53084)
JOHN DEERE 5125R...
2009 Ford F-650 24 ft Box Truck - 6.7L Cummins L6 Engine - Automatic Transmission - Low Mileage (A52748)
2009 Ford F-650 24...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
