Oil from breather tube on a dk50 se HST
   / Oil from breather tube on a dk50 se HST #1
liberty2701
Lakes region,NH
Kioti Dk50se hst
Well I have my new tractor up and running and besides a few dealer set up problems, everything is good. I made a mistake of operating the loader with the rear remote lever in the B position causing the pump to over heat and burning up some o rings. Dealer replaced it under warranty which was great. My previous Massey did not have this lever since it had a third hose at the bh (power beyond) to circulate the fluid to prevent this. Learning curve for me. The problem now is I am getting fluid from the breather at the rear of the tractor( dealer was closed). I know this is not normal. What do you think?
   / Oil from breather tube on a dk50 se HST #2
Oil is leaking out of the vent on the filler cap at the rear of the tractor? I have never heard of this and is so I would come to think that your hydraulic oil level is to high. Good luck.
Filler cap does not have a vent. There is a 90 degree brass vent with a rubber hose attached leaking fluid
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
2022 Coras Predator Steel End Dump Trailer (A56438)
2022 Coras...
2023 Ford F-150 Crew Cab Pickup Truck (A59230)
2023 Ford F-150...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
208789 (A60430)
208789 (A60430)
