sheet rock question
   / sheet rock question #31
It is rather common in high end homes and in communities where the codes are a bit harder. Screwed and Glued that is. Still nail off perimeter of board but screw double sets on each stud with glue on each stud on all walls. Hung for a good number of years & both older brothers ran their own companies (I worked with them on & off when they needed extra hand.)
Cost of glue is not too bad 20~25/case & is only about 1~2 cases per average 3k foot home, maybe 2.5 for a bigger home or one with 9+ walls. PL glue which stays pliable for a LONG time & normally hand ceilings and then glue only walls finish off one or two rooms then screw them all off.
There are lots of local codes that all want something different, one inspector wanted the screws 2.5~3 inches apart with 16~18" between pairs. Guy would take 2 hours in a house measuring these distances and if he found more than 10 he would fail the home & require individual marks on ALL screws... :/ He didn't last too long for the town (very high end homes Million plus finished cost.)
m
   / sheet rock question #32
Cripes, if you make decisions based on ease of future demo --rather than what gives the best possible result -- you may as well rewind the clock and build to 1950 standards. Someone I know once used the same argument against spray foam insulation, because he was worried what would happen if there was ever water damage around windows. I'd say let the pros do it in the way that gives the best possible result "now" and keep the hypothetical demo what-ifs out of it.
Hmmmm. I have removed drywall to:
Repair rodent damage to wiring, Replace faulty tub plumbing, repair water damaged and moldy rock from broken pipes. Replaced doors, as well as demo'd entire rooms to remodel a home.
I'd say I prefer to not deal with glue issues. But that is just my .02. I have also dealt with many "Pros" who's skills were not as advertised.
My wife and I finished the shell of a log home we had built in 2004. The only issues to date in that home were done by the "pro's" We wired, plumbed, tiled, built the staircase, Great room fireplace, walk-out basement retaining walls, paver patios, etc. The log home contractor couldn't even build a square soffit. :rolleyes: And he came with many recommendations. The building inspector asked me to replace the porch stairs because they were not code. The well line had to be replaced because he didn't think it needed to be buried in sand like someone requested....:rolleyes:
We just updated one of the bathrooms in our present home, and the builder glued the cabinets to the drywall, and the drywall to the studs. Ask my wife how much wasted time the glue caused....
   / sheet rock question #33
We are going to have some sheet rock installed. Evidently the new norm is to glue the rock on with a minimum of screws or nails. Anyone have an opinion about this method.
:2cents:
Use screws!! No nails... no glue!
   / sheet rock question #35
I'm amazed some people still use nails, that is such an old way of doing thing but it must be much faster, no drills or cords.
Nails are like 25% as much as screws, and in some situations they can be more convenient; such as fire rocking a party wall in the trusses. But I wouldn't recommend them on a visible wall.
UNUSED LANDHONOR LHR-LB9510 GAS LEAF BLOWER (A54757)
UNUSED LANDHONOR...
1998 INTERNATIONAL 4700 4X2 LIQUID TRANSFER TRUCK (A51406)
1998 INTERNATIONAL...
2022 JOHN DEERE 331G LOT NUMBER 96 (A53084)
2022 JOHN DEERE...
5' S/A CART (A52706)
2015 Jeep Cherokee Latitude SUV (A53424)
2015 Jeep Cherokee...
