sheet rock question
   / sheet rock question #11
Had some drywall repairs in a mobile home once that was glued. Had to hand chisel the glue off careful not to remove too much wood. Small patches took three times the time.
I personally wouldn't want mine glued. And if the refused to screw it in place would be looking for a different crew.
   / sheet rock question #12
Only place I've ever seen that done is in mobile homes. I couldn't tell the difference, it looked normal and there wasn't anything to suggest it was glued up, but it sure was a mess taking it down!!!!!
I like screws. I can get a box of screws for under $20 to do a room. What does the glue cost? Is this just for walls, or do they glue the ceiling on too?
In homes with sunken floors, I've used liquid nails to glue the bottom of the sheetrock in place. Did the same with the baseboards.
Eddie
I some times disagree with Eddie (ie 2x4 trusses) but I 100% agree this time. I would use all screws. Nails pop as the woods expands and contracts; screws hold good, and can be removed before you mud the heads.
   / sheet rock question #13
^ This!!!
   / sheet rock question #14
If you or anyone in the future is going to replace that rock, plan on twice the demo and cost as the stud will need to be either scabbed out or replaced.
Good luck. IMO this practice only makes the initial install quicker for the contractor, and darn near impossible to replace the rock if needed due to mold, water damage, electrical repairs etc.
I would personally forbid the contractor from doing it!
I feel the same way about spray foam. I realize it insulates better but wow what mess if you half the remove it for a future reno.
   / sheet rock question #15
The main reason they are using construction adhesive is to minimize nail pops, which also happens with screws. Don't matter what the faster is if the sheet moves and puckers around the fastener. Some if you seem to think its a shortcut, but it's done to improve results (and it takes longer since it adds a step). Our drywall guy said it cut way back on his warranty repairs. I can believe it -- we have only one pop in a 2900 sq ft house after 1 year, which is quite good considering how much the structure settles in that first year.
   / sheet rock question #16
Whey does the sheetrock pop from the nail holes? Usually because the sheetrock isn't tight against the stud and it's moving around on the wall. Best way to fix that is put a screw above and below to problem and snug it down without breaking the paper. The other reason is the house is moving too much and it wont matter how the sheetrock is attached.
Eddie
   / sheet rock question #17
That or from misses that no one pulls. Really shouldn't get pops with good tight, slightly dimpled screws.
   / sheet rock question #18
+1. For residential construction, glued and screwed, absolutely, IMO.
   / sheet rock question #19
We are going to have some sheet rock installed. Evidently the new norm is to glue the rock on with a minimum of screws or nails. Anyone have an opinion about this method.
We are General Contractors, have installed tens of thousands of boards of sheet rock. Glue won't hurt, but still needs to be screwed off every 12 to 16 inches in the field, and 8 to 10 inches on the seams. Any less is just " cheap ". Probably should ask your local building dept. for code compliance.
   / sheet rock question #20
There is a recently developed "lightweight" Sheetrock on the market now. I don't know much about it but saw it advertised in lumberyards. As for glueing the board to studs, I have seen it done but not in my own houses.
My current house is 5 years old now and no pops to screws or nails have occurred. You should definitely get the approval of code enforcement about the glue method.
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A55302)
2019 Krause...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A54756)
KNOW BEFORE YOU...
2015 CASE 580N (A47477)
2015 CASE 580N...
2008 CATERPILLAR 304C CR EXCAVATOR (A51406)
2008 CATERPILLAR...
2009 Pierce 105ft. Ladder T/A Fire Truck (A53422)
2009 Pierce 105ft...
