Kubota 7040 with Landmark 15 ft batwing
   / Kubota 7040 with Landmark 15 ft batwing #1
CBW
Waxahachie,Tx
Kubota 7040
batwings will not lay down after being raised to vertical
   / Kubota 7040 with Landmark 15 ft batwing #2
Check for selector above hyd port. Should be on single line in and out.
Yours is set for two line operation, I think....
   / Kubota 7040 with Landmark 15 ft batwing #3
There's no selector port on my '11 M7040. I just plug single or double acting cylinder into breakaways and raise/lower cylinders. Do you have breakaway couplers seated properly??
   / Kubota 7040 with Landmark 15 ft batwing #4
Check your "books" I think that using a single acting cyl. requires using the proper (flow) direction outlet. On one (JD) tractor I had, I had to only partially move the valve lever with the single acting cylinders to lower.
2018 JLG 2632ES 26ft Electric Scissor Lift (A53421)
2018 JLG 2632ES...
2019 FREIGHTLINER CASCADIA DAY CAB (A54607)
2019 FREIGHTLINER...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
UNUSED LANDHONOR LHR-DFP10 DSL FUEL TRANSFER PUMP (A54757)
UNUSED LANDHONOR...
2017 Ford F-250 Knapheide Enclosed Service Truck (A55788)
2017 Ford F-250...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
