Kubota 7040 with Landmark 15 ft batwing
   / Kubota 7040 with Landmark 15 ft batwing #1
CBW
Waxahachie,Tx
Kubota 7040
batwings will not lay down after being raised to vertical
   / Kubota 7040 with Landmark 15 ft batwing #2
Check for selector above hyd port. Should be on single line in and out.
Yours is set for two line operation, I think....
   / Kubota 7040 with Landmark 15 ft batwing #3
There's no selector port on my '11 M7040. I just plug single or double acting cylinder into breakaways and raise/lower cylinders. Do you have breakaway couplers seated properly??
   / Kubota 7040 with Landmark 15 ft batwing #4
Check your "books" I think that using a single acting cyl. requires using the proper (flow) direction outlet. On one (JD) tractor I had, I had to only partially move the valve lever with the single acting cylinders to lower.
2018 KENWORTH T800 DAYCAB (A53843)
2018 KENWORTH T800...
2012 Ford F-550 Enclosed Service Truck (A55788)
2012 Ford F-550...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A55852)
2014 Peterbilt 384...
Chop Saw and Max 43 Plasma Cutter (A54865)
Chop Saw and Max...
2013 Audi A6 AWD Sedan (A55758)
2013 Audi A6 AWD...
