Simple explanation: You would be trying to hold up the stabilizer with a vacuum. That is only 15 psi if there is no seal leakage. All seals do leak, and most of them are "energized" (industry term) by the pressure behind them. With a vacuum behind the seal, it will do a poor job of holding. Also if the induced weight exceeds the available 15 PSI, then you will just have a vacuum in the cap end of the cylinder and it will also fall. Your rod end scheme is the best, but has inherent risk.
paul
I was pretty sure it wasn't going to work based on how I checked it in the beginning. I loosened the end fitting, no oil came out. I loosened the rod end and oil came out - it started to drop.
I was 99 % sure it would not work with the valve at the other end.
dfkrug was curious, which then made me curious. Imagine after all this write up and thought, someone comes along and says just put the valve at the other end, Mine works fine on the other end.
It is too bad there is not a simple on/off valve with a built in fluid bypass if under high pressure one way. Do you know techman if such a valve exists?
Just want to Thank You again
techman:thumbsup: for bringing this to my and others attention of the danger and problems that could /will arise from installing a valve at the rod end.
This is a perfect example why these forums are a good place to hash out ideas, and is one of the reasons why I share what I have done and what I want to do to my tractor.
When I post a New Mod I'm also looking for input on how to make it better. Please don't anybody ever be afraid of offending me or to offer suggestions, criticize or leave feedback good or bad, as in this case a
warning.
But if you want to post negative stuff for no other reason then jealously or spite, as was that one case before, just move on.
