Unknown function of lever(see pic)
   / Unknown function of lever(see pic) #21
i dont think there is any chain in your tractor, probably gears.
   / Unknown function of lever(see pic) #22
View attachment 384430I am the new owner of a Yanmar 3110 and see this lever that I don't know it's function. I ordered a service manual from Hoye but I can't find the description of this lever in the manual and the pics aren't very clear in the service manual. I have not moved it with tractor running but did move it while engine was stopped. It moves easily but I just don't want to mess with some thing I know noting about. Can someone please tell me what the functionality of this lever is and how should it be used? It's the lever just below the gear shift decal. Thanks in advance...alorio1
Looks to me like a 3-speed PTO lever. wish my LS had that !
   / Unknown function of lever(see pic) #24
336d also has similar lever, similar location ..
Reason I made the statement that I didn't believe the 336 had this is, I've not seen it in my operators manual. I guess I just never noticed it in there. I remember Fredricks said it had something to do with creeper gear. I just couldn't remember exactly what he said. It's tough getting old ;)
   / Unknown function of lever(see pic) #25
That places the tractor in creeper or crawl. With the clutch in,
rotate the lever 1/4 turn clockwise so it is pointing toward the seat. While holding the lever toward the seat push the gear lever from the (1) position to the (C) position which is above first speed as shown on the sticker. Release the clutch and the tractor will creep very slowly forward. Mine is a D model so it is 4 wheel drive with a hydro drive lever so I have an additional 3 forward crawl speeds and 1 reverse.
   / Unknown function of lever(see pic) #26
many have said here that its like .3 MPH or something rediculously slow so there is absolutly no need for it. They said its so slow you almost have to get off and go inside and come back out to even see it move!!
   / Unknown function of lever(see pic) #27
I have heard it is the gear you use if you want to see the seasons change while putting the tractor in the barn. :D
   / Unknown function of lever(see pic) #28
I honestly cant imagine why even on a rice tilling tractor you would want to go that slow? Maybe its the gear you use for moving houses or 50000 pound trailers?
first gear on my YM2000 is so slow that i dont think i have ever seriously used it other than testing or just messing around?
   / Unknown function of lever(see pic) #29
The only way I have ever used my creeping gear is when the yard is filled with sticks from a hurricane I put it in first and creeper and let it ride along across the lawn while I pick up all the little sticks and put it in the bucket
   / Unknown function of lever(see pic) #30
Yes, it is so slow that you can get off the tractor and watch it move very slowly. I have a pond behind my house and I have a little flat bottom skiff to paddle around the pond. Snakes were getting under the boat and when I would move the boat they would hit the water. I hooked the tractor to the tow line, put it in crawl, got off and stood by the water with my shotgun. As the line tightened the boat slowly started to pull away. When the snake came out I was ready for him. You can walk 10 times as fast as the tractor moves, so I wouldn't be above hooking a trailer behind it and throwing sticks in it after a storm. When they say crawl, they mean, crawl.
CFG Industrial STSD10 Grain Drill (A50121)
CFG Industrial...
2014 Ford Explorer AWD SUV (A50324)
2014 Ford Explorer...
2017 John Deere Gator TS Utility Cart (A50324)
2017 John Deere...
2014 Dodge Grand Caravan Van (A50324)
2014 Dodge Grand...
Case International MDX91 3pt Disc Mower (A50774)
Case International...
