Basement upgrades...Allure vinyl flooring is my new best friend:
/ Basement upgrades...Allure vinyl flooring is my new best friend: #1
MotorSeven
Elite Member
NE TENN (Hancock Co)
Kioti DK40SE Hydro
I first used this stuff last year on a flip house and really like the way it looks. But the best part is the ease of installation. We have company inbound, so I decided to floor half of the basement, then wall off a bedroom. I installed 700ish sq feet of Allure in about 5 hours by myself. Walls go up today.
$1.56 a sq ft at Home Desperate:
Once you get set up, you can run two rows at the same time:
A tape measure, pencil, straight edge and a box cutter with a sharp blade is all you need. No underlayment needed, completly free floating and waterproof:
A chimpanzee coud install this stuff....which is why I am able to get it done....ok I admit, I am more of an Orangutang:D
Redneck Corona's.....High Life with a lime:thumbsup:
/ Basement upgrades...Allure vinyl flooring is my new best friend: #4
I did a small casino in that vinyl plank, including the bar. Most cannot tell it from real wood.
/ Basement upgrades...Allure vinyl flooring is my new best friend: #5
MotorSeven i have some basement flooring to do soon, and i like that this product
won't get ruined by some water.
my basement has pressure treated plywood glued/screwed to the concrete floor,
and even though it should be rigid there are some places that the plywood must not
be tight to the floor so sometimes you feel a little give to the floor.. i wonder if this
product will be ok to use over that plywood? do you think a little flex will bother it?
nice job btw!
Dutch...slap it right down, it has plenty of flex so I don't think you will have a problem.
Dutch I shot this for you....bend it all the way, then it goes right back flat with no problem:
If it has any drawbacks it is the weight....the stuff is HEAVY. Also, the boxes they are packaged in are slick. I mean I swear I think they wax them at the plant like a surfboard. I know this because heavy tall boxes will launch right off the back of a flatbed on a moderate incline even though they were wrapped in plastic and strapped down.
/ Basement upgrades...Allure vinyl flooring is my new best friend: #8
Yep, we've used this flooring on several projects, including the front porch at our fishing camp. So far it has held up great, even outdoors where it is not intended.
/ Basement upgrades...Allure vinyl flooring is my new best friend: #9
Is this something you would put in your living room as we have a 95 lb. dog and would like a vinyl floor as it is water proof and hopefully scratch resistant . We put down a wood laminate in the bedroom and that will scratch but looks very nice , just have to keep the dog off it .
/ Basement upgrades...Allure vinyl flooring is my new best friend: #10
It's tough stuff. You just need a clean flat surface and make sure you prime the floor first with there primer.
/ Basement upgrades...Allure vinyl flooring is my new best friend: #11
Agreed. I just did my basement with these, easy to work with and very durable. Much better than the 1' X 1' gluedowns.....which I used on the last basement, and are peeling up....
/ Basement upgrades...Allure vinyl flooring is my new best friend: #12
that looks great!
/ Basement upgrades...Allure vinyl flooring is my new best friend: #13
Thanks for the review! My basement workshop is in desperate need of something-I've been contemplating the 1x1 commercial square tile (VCT) and gluing them down.
How do you think a mill (2,200lbs) and lathe (1000lbs) would do sitting on it?
Ken, if you put some kind of footpad under those heavy machines I think it would be fine.
/ Basement upgrades...Allure vinyl flooring is my new best friend: #15
This stuff is great I just used it in our camper. Last year durning hunting season our vinyl floor split in several places. I pulled it out and but this in. Very easy to work with.
/ Basement upgrades...Allure vinyl flooring is my new best friend: #16
Include me in the Allure fan club. I've installed it for a dozen or so clients and everyone loves it.
Eddie
/ Basement upgrades...Allure vinyl flooring is my new best friend: #17
I have the Allure in Hickory in our basement and its great.
Why do you say prime the floor?
/ Basement upgrades...Allure vinyl flooring is my new best friend: #18
Yea, I've used this product a few times and it's very user friendly. I've generally limited it's use to bathrooms where we wanted to upgrade from sheet vinyl, but didn't want to go to tile. It also doesn't have the hollow sound that laminate has.
The product floats so I don't know why a primer would be needed.
/ Basement upgrades...Allure vinyl flooring is my new best friend: #19
Good Afternoon Kenny,
When I was a modelmaker for Pitney Bowes, we had the commercial square tile on our shop floor, and we used these square fiber pads under all the corners of our mills and lathes. Never had a problem when we needed to move something around in the shop. They pretty much eliminated any damage to the tiles !
Im not sure of the proper name for them,,,:)
/ Basement upgrades...Allure vinyl flooring is my new best friend: #20
from what i have read, the primer is more of a sealer, they don't want moisture weeping up
from under a concrete floor and becoming trapped between the floor and concrete.
2025 GIYI GY-PG72C 72in Dual Cylinder Grapple Bucket Skid Steer Attachment (A59228)
2025 GIYI GY-PG72C...
12FT X 20FT LIVESTOCK METAL SHED (A58214)
12FT X 20FT...
(APPROX. 640BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 640BF)...
Bobcat mid mount mower M60-5 60" CT2025
Bobcat mid mount...
2008 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2008 Godwin...
2020 FREIGHTLINER CASCADIA SLEEPER (A59904)
2020 FREIGHTLINER...
