YanMar 2210 Factory Crack spec's???
   / YanMar 2210 Factory Crack spec's??? #1
Strayhorn, MS
Yanmar
YanMar 2210 Factory Crack spec's??? Does anyone know what the factory Crack specs are for a 81 2 Cylinder 2210 Tractor. Also if its handy I would also like the spec's on the cam and rods.. Thank You in advance.:cool2:
   / YanMar 2210 Factory Crack spec's??? #2
According to Hoye's parts the 2000 and 2210 use the same crank and rods so here is what the I&T manual shows for the 2000.
Thank You! Going to go and see about get the crack turned, its a long shot but I have a contact at Bullet racing cams and they can turn it as long as its not cut to deep for 185.00 verses 450.00 for a new one.
Thanks Again!
   / YanMar 2210 Factory Crack spec's??? #4
According to available bearings they can turn the crack .030".
   / YanMar 2210 Factory Crack spec's??? #5
That's about right since my John Deere mechanic said the same thing for my Yanmar 3T80 in a JD-850. Are we talking crack or crank here :D
   / YanMar 2210 Factory Crack spec's??? #6
I kept seeing "crack", so assumed it must be some type of code.
   / YanMar 2210 Factory Crack spec's??? #8
Wife says I need to readjust my "spenders" because I am showing more crack. Other wise the felons at the end of the road, could educate the rest of us on "crack".
   / YanMar 2210 Factory Crack spec's??? #9
What I thought also. I know with the new Fad of Wearing your your Draws down around your Hips. But 30" of Crack ? That did sound a little much or either on it.:p
48ft all aluminum feather light wedge trailer (A56436)
48ft all aluminum...
NON RUNNING 2019 Ford F-550 Truck, VIN # 1FDUF5HT1KEC13083 (A57453)
NON RUNNING 2019...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
Echo Weed Eater (A55272)
Echo Weed Eater...
INOP 8ft Rotary Cutter (A57454)
INOP 8ft Rotary...
2008 Ford F-350 4x4 Crew Cab Pickup Truck (A56858)
2008 Ford F-350...
