YanMar 2210 Factory Crack spec's???
   / YanMar 2210 Factory Crack spec's??? #1
Strayhorn, MS
Yanmar
YanMar 2210 Factory Crack spec's??? Does anyone know what the factory Crack specs are for a 81 2 Cylinder 2210 Tractor. Also if its handy I would also like the spec's on the cam and rods.. Thank You in advance.:cool2:
   / YanMar 2210 Factory Crack spec's??? #2
According to Hoye's parts the 2000 and 2210 use the same crank and rods so here is what the I&T manual shows for the 2000.
Thank You! Going to go and see about get the crack turned, its a long shot but I have a contact at Bullet racing cams and they can turn it as long as its not cut to deep for 185.00 verses 450.00 for a new one.
Thanks Again!
   / YanMar 2210 Factory Crack spec's??? #4
According to available bearings they can turn the crack .030".
   / YanMar 2210 Factory Crack spec's??? #5
That's about right since my John Deere mechanic said the same thing for my Yanmar 3T80 in a JD-850. Are we talking crack or crank here :D
   / YanMar 2210 Factory Crack spec's??? #6
I kept seeing "crack", so assumed it must be some type of code.
   / YanMar 2210 Factory Crack spec's??? #8
Wife says I need to readjust my "spenders" because I am showing more crack. Other wise the felons at the end of the road, could educate the rest of us on "crack".
   / YanMar 2210 Factory Crack spec's??? #9
What I thought also. I know with the new Fad of Wearing your your Draws down around your Hips. But 30" of Crack ? That did sound a little much or either on it.:p
New/Unused 14ft Bi-Parting Iron Gate (Cow Design) (A57454)
New/Unused 14ft...
1999 TRANSCRAFT FLAT BED 48FT TRAILER (A59575)
1999 TRANSCRAFT...
1988 ASPT Patterson Trailer (A57148)
1988 ASPT...
UNUSED JCT 72" HYD BRUSH CUTTER (A58376)
UNUSED JCT 72" HYD...
light tower (A56857)
2016 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A52709)
2016 CATERPILLAR...
