LS Tractor Oil, Gas, & Air Filter Information
   / LS Tractor Oil, Gas, & Air Filter Information #121
Any XR3037HC owners done their 50 hour service yet? If so, do you have a filter part# listing.
Thanks
George, Any new info on this or a cross reference for the oil filter??
   / LS Tractor Oil, Gas, & Air Filter Information #122
See post 99 for the list.
Still no cross reference I know of for the oil and fuel filters. Eventually the aftermarket will catch up.
I bought all mine from the dealer. Waiting till the magic 50 hour mark to change them.
Like you said in the other post, no harm in changing them early. I may do mine at 40 hours.
   / LS Tractor Oil, Gas, & Air Filter Information #123
2014 LS XR4046HC Engine Shibaura (Tier 4): N844L-F
(Old) Oil filter NAPA # 1056 / WIX # 51056
(Improved) Oil filter NAPA # 1348 / WIX # 51348
Fuel filter NAPA # ----- / WIX # -----
Hydraulic Filter NAPA # 1715 / WIX # 51715
(Old) Hydro Trans Filter NAPA # 1553 / WIX # 51553
(Improved) Hydro Trans Filter NAPA # 1551/ WIX # 51551
Inner Air Filter NAPA # 6490 / WIX # 46490
Outer Air Filter NAPA # 6489 / WIX # 46489
Changes made annotating that a better filters are available
*The original numbers are what my dealer recommended, the new p/n's have better ratings.
   / LS Tractor Oil, Gas, & Air Filter Information #124
Oil filter NAPA # 1056 / WIX # 51334
Napa 1056 DOES NOT cross to a WIX 51334 It crosses over to a Wix 51056, Wix 51056, Wix 51056MP, Wix 51335 or a Wix 57035 I am told the filters i just listed in Wix will fit the XR3037. It is a shorter filter but has a funky check valve in it. $12.95 at O'Rielly's on a jobber account. Picked a 51056 up a half hour ago.......
   / LS Tractor Oil, Gas, & Air Filter Information #125
Looking at the cross references online i see that the New Holland Boomer 33 uses the same engine, Shibaura N843T-F-27 Turbo. New Holland rates it at 33HP and LS at 36.5 hp. Not sure if the New Holland is Tier 4 or not though. Logic would tell you that the filter from New Holland would fit the LS being it's the same engine. I'm going to use the Wix 51056 as i have it from a good source that it is the proper cross. I change every 100 hours anyways after initial break is so a smaller filter don't worry me......
   / LS Tractor Oil, Gas, & Air Filter Information #126
Here are the specs on the Wix 51056 for the XR3037
Part Number: 51056
UPC Number: 765809510562
Principle Application: Various Lawn & Garden Equip. + Small Tractors w/Briggs & Stratton, Hatz, Kawasaki, Kohler, Lister Engines
Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 2.707
Outer Diameter Top: 2.921
Outer Diameter Bottom: Closed:
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=6/20
Burst Pressure-PSI: 325
Max Flow Rate: 7-9 GPM
Nominal Micron Rating: 21
Gasket Diameters Number O.D. I.D. Thk.
Attached 2.734 2.430 0.226
   / LS Tractor Oil, Gas, & Air Filter Information #127
I have tried to find a part # or a cross reference for a oil filter for a 2013 ls g3033, anyone have any info would be greatly appreciated
   / LS Tractor Oil, Gas, & Air Filter Information #128
See posts 71 and 68.
The G3033 and 3038 take the same filters
   / LS Tractor Oil, Gas, & Air Filter Information #129
That is what I said too. Alex from RCO tells me that this is a different kind of filter because of the special check valve in it, which will void the warranty if not used. He also told me that they teach them in the dealer training that it is a 500 hour filter. I guess this first change is just really a safety thing to get rid of any build crap that has busted loose in the engine. The user manual says change the oil every 250 so I may have misunderstood Alex. It does say the fuel filter is 500 hours.
Alex, if you are reading, (he says he reads here all the time, which is a good thing) please feel free to correct me if I mis understood.
I shudder to think that there may be stuff floating around in there and the hydros like that stuff that was falling out of my ceiling.....I think I'll cut mine open after changing to make sure. It looks like the filter are standard cases, I'm going to get the thread pitch , diameter and cross it to a cheap autozone filter and do a secondary cheap oil and filter 1 hour flush just to make sure before installing the new 50 buck one and good oil if I see anything in the filter when I cut it open.
My dealer said any good quality filters can be used and it will not void the warranty.
Eugene
   / LS Tractor Oil, Gas, & Air Filter Information #130
Thanks I guess I overloooked it. I am not having any luck cross referencing that filter. Tried to cross it on wix website, with no luck.
Anyone have any luck crossing it with another filter?
2006 BMW 325i Sedan (A55853)
2006 BMW 325i...
HOBBS 48FT FLOAT (A55745)
HOBBS 48FT FLOAT...
1981 LUFKIN 41 FLATBED (A55745)
1981 LUFKIN 41...
2015 MACK CHU (PINNACLE) TRI AXLE(INOPERABLE) (A55745)
2015 MACK CHU...
