MitchellB
Gold Member
- Joined
- Jul 22, 2012
- Messages
- 389
- Location
- Greensboro, NC
- Tractor
- 1958 861D Ford Powermaster Diesel & 2016 Husqvarna YTA24V48
Took the (new to me) 861 out finish mowing yesterday afternoon. Seemed to do good for about an hour. I wasn't even running at full PTO speed on the tach, but about 3/4 (needle straight up) mowing in third gear. I had just finished one small field and had moved to the other portion. Grass was about two weeks since I had mowed last, so thick in places, but nothing that should strain it much. I heard something clank and thought at first the mower had hit something as the engine seemed to bog down. I quickly hit the clutch and took the PTO lever out of engagement and noticed the RPM/Tach had stopped working altogether. The engine seemed to be out of time struggling to run. I limped her back to the shed, although I wasn't sure she'd make or if I should even try. She was beginning to run hot when I shut her down and would occasionally spit out flecks of red hot carbon specks from the exhaust stack just before I got under the shed. My first guess is the hydraulic pump that the RPM cable connects to, but I'm new to diesels, so I'm not sure really what happened. I hope this new 55 year old tractor didn't just die a major death on me. Any advice on where to start or what happened?
Undid the tach cable and it does not appear damaged and turns freely in my fingers. Tried cranking the engine today, but would not fire up. I tried engaging lift (lever up) to see if spinning the engine with the starter would raise my mower up off the ground, but it did not move either. So maybe I have two problems that began at the same instance? Bad pump? (by the way I changed the hydraulic fluid but never used the lift much running the mower yesterday) But why would a bad pump affect the engine? Pull the pump to inspect the gears first? Maybe I need to keep my 8N?
