JD 2320 drive shaft repalcement
   / JD 2320 drive shaft repalcement #11
Here is the Owner's Manual Update:
  • 2320 Update.pdf
I now have my tractor back with a new drive shaft assembly installed from the dealership. My dealership has been good to work with, and even though the tractor is 5 years out of warranty at this point, they acknowledged the lack of information in the owner's manual concerning the driveshaft and u-joint lubrication. They worked with the regional JD representative, and we all agreed to pay 1/3 of the cost on the parts which was $663.66. JD paid 1/3, the dealership paid 1/3, and I paid 1/3. the dealer gave me a flat shop rate of 3 hours to remove and install the driveshaft - $ 256.00, even though they spent about 7 hours on it. They agreed to not charge for the pick up and delivery. I am about 30 miles away. Overall, I was out of pocket $500.94, and they had the tractor for about a week until everything was worked out. I felt it was a fair outcome. I took the old driveshaft to a driveline shop, and if they can find a replacement u-joint, it will be about $75.00 to repair the old one. So far they have not found an exact fit. JD does not have a part number just for the u-joint, and only sell it as an assembly. My guess is that is the way they get them from their supplier, and it was designed by someone other than JD. I cut an access hole in the plastic cowling, and screwed on a cover plate that I can now remove and keep the u-joint lubricated. hopefully I do not need to go through this again. Thanks everyone for all the information.
   / JD 2320 drive shaft repalcement #15
Jim, thanks for the update!
   / JD 2320 drive shaft repalcement #16
Wow, 7 actual hours in a dealers shop is a lot of work. Does anyone know how this is done? Do they have to drop the transmission/differential out of the tractor?
   / JD 2320 drive shaft repalcement #17
Thanks for the update. Glad to hear you came to an agreeable solution. Also glad to hear JD step up.
   / JD 2320 drive shaft repalcement #18
I greased the rear shaft today from the bottom but could not get the front one from the bottom. I will try the front one on a day when I have time/patience. Read lots of posts and will try the splitting the panels below the dash and accessing through the inspection port method.
   / JD 2320 drive shaft repalcement #19
It is a real PITA for sure. I took the panels apart to access the joint. I put a ratchet on the crankshaft bolt to position the joint where I want it. Just DO NOT forget to take the ratchet off the crank bolt before trying to start it, that could get quite messy. It's all I can do to squeeze my hand in there with a grease gun. I use a battery one so I can do it one-handed. I cannot get a normal gun fitting to latch onto the zerk, so I use a needle and I bent it at a slight angle to fit in there better.
   / JD 2320 drive shaft repalcement #20
Is this experience talking? :D
2016 KOMATSU PC240LC-11 EXCAVATOR (A60429)
2016 KOMATSU...
Commercial truck Frame with Axle (A59230)
Commercial truck...
2013 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A59904)
2013 FREIGHTLINER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
excavator trenching bucket- one bucket per lot (A56438)
excavator...
2004 Saturn VUE SUV (A59231)
2004 Saturn VUE...
