OK, so I bought this 2210BD early spring from Coldwater tractors and have been using it lightly off on this spring but nothing for approx 2 months. Mostly post holes this summer. Went out today and used it a little loading dirt into my raised beds for next spring. All of a sudden the front right hub wanted to turn suddenly/ shaprly. I tried to limp it to the shop so as to work on it and it stopped completely and wont turn?
The left rotates and the right wont turn at all.
So when I bought it, I thought I changed all fluids, including the for the front diff. However in looking at this thing now in the pics, the assembly for the wheel looks like it has a drain plug in the bottom of it (see photo) and the other pics shows a small nut that MAY be a filler????
That said, did I destroy something, any ideas and if so, whant even get it and is it expensive. Right now I cant even get it to the shop. If this is a reservoir, what oil and its probably too late?totally bummed as I spent every cent I had to buy this and cant even afford to fix it at this point if its broken or expensive. any advise is very appreciated.
Im
Thanks for any advise in advance.
RUMBLON in Idaho.
the culprit
Does this look like its separating
the diff was full
is this a drain plug, I am new and admit it, I didnt service this, just the front diff. Did I screw the pooch?
and is this a filler nut?
Im
RUMBLON in Idaho.
the culprit
the diff was full
