What grease gun are you using??
   / What grease gun are you using?? #81
my day to day gun is the legacy pistol grip gun from tractor supply(about $35) I actually have about three of them so theses always one around, but I keep an alemite handle pump 10,000psi unit (about $150) for stubborn/ neglected grease fitting that need some extra oomph. I like them both and
   / What grease gun are you using?? #82
I've had this Craftsman air powered grease gun for 6 or 7 years and it's still working great...
   / What grease gun are you using?? #83
I run two air powered grease guns, one loaded with grease for the loader/back hoe, the other with regular grease. Both are cheap HF guns I paid $12 each about eight years ago and still working perfectly.
   / What grease gun are you using?? #84
Have a Husky pneumatic gun and a Lucas manual gun. Just received two Lock N Lube couplers to install on the guns.
http://youtu.be/A5uccLIC99w
Also have a small manual gun, from TSC, that takes the small cartridges to get to hard to reach zerks.
Sent from my iPad using TractorByNet
   / What grease gun are you using?? #86
I have a small grease gun too, and it can be handy when you are crawling around under a vehicle in limited space, but did you see my thread on an addition to your LockNlube arsenal? This right angle adaptor is very useful.
http://www.tractorbynet.com/forums/...51-accessory-your-lock-n-lube.html?highlight=
   / What grease gun are you using?? #87
I have a small grease gun too, and it can be handy when you are crawling around under a vehicle in limited space, but did you see my thread on an addition to your LockNlube arsenal? This right angle adaptor is very useful. http://www.tractorbynet.com/forums/owning-operating/318651-accessory-your-lock-n-lube.html?highlight=
Hi James;
Yes, I did see your thread on the right angle adapter. I think they have them at Tractor Supply and plan to pick one up.
The only zerks that give any problems are the ones on PTO shaft U joints. They are angled but, the guard is in the way. This is where I use my small gun. May be no problem now I have the Lock N Lube.
Thanks for sharing the RA adapter!
   / What grease gun are you using?? #88
I realize this THREAD is a couple months old but (there's always one of those), I bought a small grease gun that has a multi purpose "SD (I think it said) 3oz tube of grease with it from my Deere dealer for $12.95 with the intent of greasing the zerts on the riding Deere 48" cut mower. We'd only used the mower a few times due to drought so it's yet to need greasing. SO, the question is: Will this gun and grease be sufficient for my first go on hitting all the zerts on my CK30? Finally reached that hour point where I best start making sure everything is properly greased. Yes, I will get more cartridges, probably next week, but I'm thinking I'll be good to go for the first "greasing the beast" adventure.
Thanks as always fellas :)
Jeff
   / What grease gun are you using?? #89
The small guns can be handy of newer stuff requiring little grease but I do not use ours due to grease cost.
   / What grease gun are you using?? #90
I refill the small tubes with my large grease gun. I just put the gun tip of the large gun into the empty tube inside the grease gun and pump away. I mainly use the gun for greasing the chain saw bar but sometimes it's nice to have something compact.
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2019 KOMATSU D51PXi-24 CRAWLER DOZER (A51246)
2019 KOMATSU...
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 80in...
2022 BOBCAT T66 R-SERIES SKID STEER (A51246)
2022 BOBCAT T66...
Miles read : 112,969 (A50323)
Miles read ...
CAT 257D (A50123)
CAT 257D (A50123)
