What is the trick to making leak free welds?
   / What is the trick to making leak free welds? #21
I use a oxy/acy welding tip to weld or braze hydr tubing,never had them leak yet.
Sometimes if there was room i cut the bad section out and used a compression union.
   / What is the trick to making leak free welds? #22
I like to preheat with the propane torch... burns off the oil from the crack, and the paint nearby... contamination is the biggest cause for welding pinholes and a torch cleans them best.
Also what the other guy said, make sure its open before you weld. If some fluid inside the system evaporates it will build up pressure, which will push through your weld before the melting bath is solidified.
   / What is the trick to making leak free welds? #23
I might add ... to pay attention to arc blow/ ground placement and how the +/- flows for ya
   / What is the trick to making leak free welds? #24
Your dog is way cool.:cool:
Willmar 4500 Wrangler Articulating Loader (A55314)
Willmar 4500...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
Hose Reel (A55758)
Hose Reel (A55758)
DOOSAN G25KW GENERATOR (A53843)
DOOSAN G25KW...
HEAVY DUTY 7' X 13' X 3.5' WAREHOUSE STORAGE SHELF (A54757)
HEAVY DUTY 7' X...
