What is the trick to making leak free welds?
   / What is the trick to making leak free welds? #21
I use a oxy/acy welding tip to weld or braze hydr tubing,never had them leak yet.
Sometimes if there was room i cut the bad section out and used a compression union.
   / What is the trick to making leak free welds? #22
I like to preheat with the propane torch... burns off the oil from the crack, and the paint nearby... contamination is the biggest cause for welding pinholes and a torch cleans them best.
Also what the other guy said, make sure its open before you weld. If some fluid inside the system evaporates it will build up pressure, which will push through your weld before the melting bath is solidified.
   / What is the trick to making leak free welds? #23
I might add ... to pay attention to arc blow/ ground placement and how the +/- flows for ya
   / What is the trick to making leak free welds? #24
Your dog is way cool.:cool:
2006 SHOP BUILT 130 BBL STEEL VACUUM TANK TRAILER (A55745)
2006 SHOP BUILT...
2024 78in Hydraulic Brush Grapple Skid Steer Attachment (A55851)
2024 78in...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2016 Freightliner 114SD T/A 4,000 Gallon Water Truck (A53422)
2016 Freightliner...
BOX BLADE (A55745)
BOX BLADE (A55745)
