Yanmar mini excavator wont start
   / Yanmar mini excavator wont start #11
The injectors will be on the head of your engine with steel tubing lines going from the injector pump to them. I doubt they are your problem.
I hate to keep beating the same drum but did you try tapping on the injector pump while turning the engine over with the throttle wide open?
   / Yanmar mini excavator wont start #12
im having the same problem with my gehl 292 mini ex that has 3tne88 3 cylinder yanmar.
Pump was clogged along with injectors. There was a switch that was bad also not sure which one though. A friend of a friend borrowed it and I told him you want to use it then you have to fix it. Hes a diesel mechanic so he fixed it for free. Cant beat that
   / Yanmar mini excavator wont start #15
thanks ill see if anything is clogged up inside injection pump. my brother ran some very dirty fuel through it before he passed away. not his fault but that could be it thanks
2015 GENIE GTH-1056 TELESCOPIC FORKLIFT (A59823)
2015 GENIE...
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
2009 Mariah SC23 23ft. Cabin Cruiser with T/A Boat Trailer (A59231)
2009 Mariah SC23...
2025 GPS Equipment Trailer (A56859)
2025 GPS Equipment...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A60429)
2007 CATERPILLAR...
2008 Toyota Camry Sedan (A59231)
2008 Toyota Camry...
