Yanmar mini excavator wont start
   / Yanmar mini excavator wont start #11
The injectors will be on the head of your engine with steel tubing lines going from the injector pump to them. I doubt they are your problem.
I hate to keep beating the same drum but did you try tapping on the injector pump while turning the engine over with the throttle wide open?
   / Yanmar mini excavator wont start #12
im having the same problem with my gehl 292 mini ex that has 3tne88 3 cylinder yanmar.
Pump was clogged along with injectors. There was a switch that was bad also not sure which one though. A friend of a friend borrowed it and I told him you want to use it then you have to fix it. Hes a diesel mechanic so he fixed it for free. Cant beat that
   / Yanmar mini excavator wont start #15
thanks ill see if anything is clogged up inside injection pump. my brother ran some very dirty fuel through it before he passed away. not his fault but that could be it thanks
2014 MACK GU713 WATER TRUCK (A54756)
2014 MACK GU713...
2019 Bobcat 3400 4x4 Utility Cart (A54811)
2019 Bobcat 3400...
2022 Case 221F Wheel Loader (RIDE AND DRIVE) (LIKE NEW) (A50775)
2022 Case 221F...
10' Wheel Loader Bucket (A50775)
10' Wheel Loader...
Swict 78" Bucket (A53316)
Swict 78" Bucket...
2008 Walker Mudhog (A55787)
2008 Walker Mudhog...
