Yanmar mini excavator wont start
   / Yanmar mini excavator wont start #11
The injectors will be on the head of your engine with steel tubing lines going from the injector pump to them. I doubt they are your problem.
I hate to keep beating the same drum but did you try tapping on the injector pump while turning the engine over with the throttle wide open?
   / Yanmar mini excavator wont start #12
im having the same problem with my gehl 292 mini ex that has 3tne88 3 cylinder yanmar.
Pump was clogged along with injectors. There was a switch that was bad also not sure which one though. A friend of a friend borrowed it and I told him you want to use it then you have to fix it. Hes a diesel mechanic so he fixed it for free. Cant beat that
   / Yanmar mini excavator wont start #15
thanks ill see if anything is clogged up inside injection pump. my brother ran some very dirty fuel through it before he passed away. not his fault but that could be it thanks
2017 Jeep Patriot 4x4 SUV (A55758)
2017 Jeep Patriot...
King Kutter TG72 Rotary Tiller Tractor Attachment (A55851)
King Kutter TG72...
2025 Swict 72in Bucket Skid Steer Attachment (A53421)
2025 Swict 72in...
2011 26PS PROWLER 5TH WHEEL RV (A52472)
2011 26PS PROWLER...
1999 INTERNATIONAL F-4900 TANK TRUCK (A54607)
1999 INTERNATIONAL...
1984 GROVE CRANE (A54607)
1984 GROVE CRANE...
