Ordered a 5609 today
   / Ordered a 5609 today #71
Very nice! Glad to see you finally got your tractor. You're a patient, patient man.
Tractor has performed flawlessly to date. Most comfortable seat I've ever sat in... wish I could get one as a recliner for the house!
   / Ordered a 5609 today #75
1953 Harry Ferguson TO-30.
The 5609 has about 70 hours on it now. I'm averaging 1.04 gallons of fuel per hour over the lifetime of the tractor. The economy PTO is a great fuel saver.
Tractor remains a joy to operate. Again, the seat is fantastic. I'm getting the hang of all the different programming options.
One of my favorites is the ability to program rpm ranges (low and high). The program has the option to be on all the time, on when the PTO is on, or one when the 3 pt. hitch is lowered. For the PTO, you basically bracket 540 rpms on the PTO with the rpm range. Push a button to engage the 'program,' and another to turn on the PTO and the tractor will automatically spin up to whatever rpm is needed to maintain 540 pto rpm.
I do almost all my shifting via the joystick buttons now. You can up-shift and down-shift gears and ranges (road mode, in field mode it is gear changes only. Have to use the t-handle for ranges shifts), forward and reverse, and neutral all using buttons on the joystick. Very slick.
Used a root grapple on it and blew out the hydraulic seals on one side of the grapple. Seal was damaged by sand and grit.. Anyway, with the combined hydraulic flow, the grapple opens and closes pretty darned fast. Operation of the FEL is quick - at times, maybe too quick? Naw... Its pretty nice.
It is a great tractor. I did the 50 hours service myself and was happy how easily accessible all the filters were. Still in the honeymoon stage... :D
Really enjoying the cab on the MF. Very quiet even running at PTO rpm. Plus, its nice and dry when you have to top fields in the rain. :dance1:
   / Ordered a 5609 today #79
The 5600 Series are excellent tractors as you have experienced and the ability to customize virtually every function to your preference is fantastic. You're correct, it takes a while to get comfortable with operating all the options but once you do it is a blast to operate. The 5600 is 10 steps up from a 4600 and not really much bigger in overall size. Congrats and that equine savings is a sweet deal.....
The Equine Savings made the tractor affordable. Without it, we wouldn't have gone Red.
I'm still not proficient in all the different options - yet.
Another option I like it the dry swap for the PTO shaft to swap between 540 and 1,000. That was a lot easier than expected and completely, totally dry.
SET OF 48" QUICK ATTACH MAST PALLET FORKS (A51242)
SET OF 48" QUICK...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A52128)
2014 Doyle Dry...
2008 FORD F-750XL SUPER DUTY ASPHALT DISTRIBUTOR T (A51243)
2008 FORD F-750XL...
24 Foot Wells Cargo Enclosed Trailer (A50324)
24 Foot Wells...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51222)
2015 FREIGHTLINER...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
