Kubota BX getting rid of stump in my new potato/veggie garden
   / Kubota BX getting rid of stump in my new potato/veggie garden #11
It simply amazes me what these small tractors can do , thanks for the video . Would be interesting to see what a ripper tooth adds to the equation .
I can only speak for myself but it cuts the time in half if not more.
   / Kubota BX getting rid of stump in my new potato/veggie garden #12
OP
Save yourself a ton of time!
Cut your stumps 6-10ft off the ground
Water around the tree
Tie a strap/chain up high
Pull with a 4x4 truck or large tractor
Done!
How much time did this take you? Ridiculous
Sent from my iPhone 5s 64Gb using TractorByNet
   / Kubota BX getting rid of stump in my new potato/veggie garden #13
OP
Done!
No this is ridiculous. He wouldn't risk tearing up his 4X4 and he don't own a larger tractor. There's a lot of risk doing it the way you mentioned and you know that. He used what was available, his tractor. No risk, just a little time which you can clearly see he enjoyed. I don't see anything wrong with that. This is what he purchased his tractor for. Let him enjoy it.
   / Kubota BX getting rid of stump in my new potato/veggie garden #14
OP Save yourself a ton of time! Cut your stumps 6-10ft off the ground Water around the tree Tie a strap/chain up high Pull with a 4x4 truck or large tractor Done! How much time did this take you? Ridiculous Sent from my iPhone 5s 64Gb using TractorByNet
Sorry, but I have to chime in here as well. I have done much the same as the OP several times. Your suggestion in my opinion could be considered 'ridiculous'. I don't own or have access to a large tractor and there is no way to access using my 4x4. Even if I did I surely wouldn't abuse it that way... and oh, my stumps were not cut above my head. You are a firefighter and you make suggestions like that... hmmm? :confused3:
   / Kubota BX getting rid of stump in my new potato/veggie garden #15
I couldn't agree more , it is way to risky cutting any tree up that high as you have no idea of what that tree may do when falling ,the way of escape trying to cut a tree that high could be really bad to say the least .
   / Kubota BX getting rid of stump in my new potato/veggie garden #16
Yup works great!
Hook up a tow strap up high
Start cutting
Winch it down where you want
Takes all risk away from having an "accident"
Then tow strap up high on trunk
Pull gently
Comes right out
NP
Thanks
You just learned something
   / Kubota BX getting rid of stump in my new potato/veggie garden #17
Enjoyment in running his tractor. That's what I took from his post. Heck, I'm thinking up stuff to do with mine, just to run it or tinker with it.
I had a young friend who was concerned about my "efficiencies" in my right of way mowing business that I started up. Making more money wasn't the goal anymore for me. Finding enjoyment in what I was doing was the goal. He just couldn't understand that.
   / Kubota BX getting rid of stump in my new potato/veggie garden #18
Ok maybe I have a little Bh envy
   / Kubota BX getting rid of stump in my new potato/veggie garden #19
Yep I checked my video it was just 24 mins to get it out. I cut the tree off not many days before that and left the stump high enough to get good leverage. Not a lot of large diameter roots but lots of little ones. Didn't use anything but the BX to get it out.
Eas it a Newfie tree? Trees here in Ontario are much tougher, of course.😜
Eas it a Newfie tree? Trees here in Ontario are much tougher, of course.��
You're right our trees can't match yours for size and hardness...
(BTW I should have subscribed to my own post as I'm just now getting to read all the comments made earlier... some good some bad :)
New/Unused 72in Quick Attach Brush Cutter (A54865)
New/Unused 72in...
17101 (A55787)
17101 (A55787)
2015 Audi Q5 AWD SUV (A55758)
2015 Audi Q5 AWD...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A54811)
2019 Caterpillar...
2008 Isuzu NPR-HD Landscape Dump Truck (A53422)
2008 Isuzu NPR-HD...
Kubota SVL95-2 High Flow Cab Skid Steer (A55302)
Kubota SVL95-2...
