Need help on rotary broom hydraulic conversion
   / Need help on rotary broom hydraulic conversion #1
locknut
Kubota
Need advice on system components and layout for a C-48 Two-Way Sweepster broom.The pump would be driven off the 2000rpm pto at the front of the tractor.The hyd motor would need to turn around 540rpm to the broom drive.Long story short,I didn't discover a busted gear in one of the gearboxes till late in the restoration process.For power requirements,stand alone sweepers this size are commonly powered with 6-8hp gas engines and this particular broom was sold new to use use on 10-12hp garden tractors back in the 70's.The sweeper will be used primarily in cold weather for snow.
This is where the pump needs to be mounted,aprox 5" x 5" space.Driveshaft yoke is 3/4" w/3/16" keyway.
And the location of the motor.Currently has 7/8 hex shaft for sprocket drive but I could change that to 1" shaft,or mount motor with higher offset using another hex sprocket and chain loop to the motor.
Here's a pic of a conversion that someone done years ago.Apparently the stacked Durst boxes were not reliable.I did find a specialty shop in Ohio that had three of these and every one had the same busted gear as the one I have.
   / Need help on rotary broom hydraulic conversion #2
locknut,
Here is how I would figure component sizes required.
NOTE: These calculations are based on 12 HP direct drive to the sweeper with no gear reduction. If there was gear reduction the input torque would have to be recalculated.
Torque = HP x 5252 / RPM or 12 x 5252 / 540 = 117 ft lbs torque required to drive the sweeper based on 12 HP mentioned above.
Hydraulic motor size: torque (ft lbs) = motor CIR x pressure x efficency / (24 pi)
transpose this formula to solve for motor CIR (cubic inch/rev)
example: 117 x 24pi / ( pressure drop across the motor x efficency) or 117 x 24pi / (2000 x .85) = 5.2 CIR motor
Pump size required:
example: 5.2 CIR motor turning at 540 rpm requires 2808 CIM (cubic inches of oil per minute) @ 100% volumetric efficiency. 2808 CIM/ 2000 RPM = 1.4 CIR pump @ 100% efficient
locknut,
Pump size required:
Thanks for the calcs.I called the surplus center today.The tech wanted to know the torque in/lb requirement before he would recommend a pump/motor.I have no way of knowing that.What he did throw out there is not far from what you figured. A 4.5 cu in motor and a 1.69 cu in pump.Now here's the kicker.He said no way this will work as it takes 28HP to run the combo! Is hydraulic power this inefficient and power hungry?
1.69 cu in CESSNA 26011LZC HYD PUMP
4.5 cu in CHAR-LYNN 101-1002 HYD MOTOR
   / Need help on rotary broom hydraulic conversion #4
22 GPM at 3000 psi will require about 38 HP.
The pump is not matched to the motor.
The motor needs about 15 GPM continuous
The motor is also 1800 psi continious
   / Need help on rotary broom hydraulic conversion #5
I have a motor that came off of a broom and I think it's a char-lynn. I can take a look and see what size it is. seems like the last #'s were 1008. I do know it was chain drive stright from motor to broom.
   / Need help on rotary broom hydraulic conversion #6
I don't understand how anyone came up with any numbers at all based on the OPs information.
All we know is the following:
An original stand alone unit ran on 6-8HP.
It it turned the broom at 540RPM.
The OP wants to run the hydraulic pump at 2000RPM.
The 12HP figure came from a garden tractor that has to propel itself AND the broom. Therefore, the numbers should be run for 8HP to the broom, not 12.
   / Need help on rotary broom hydraulic conversion #7
Moss,
I was just trying to provide the OP some examples of formulas on how to size a hydraulic drive.
Locknut,
You can figure 20% power loss at a minimum going hydraulic drive Vs direct mechanical drive. Everything attachments shows a 4' x 26" diameter requires 10 - 15 GPM @ 2000 - 2500 PSI. Does not state operating RPM's though.
   / Need help on rotary broom hydraulic conversion #8
It is possible to reverse engineer things.
My post was about the recommended parts from the Surplus guys which required to much HP.
If 12 HP was the original HP, then you could reverse engineer the requirement as to the force required to make something work.
12 HP can power a 3 cu in pump at 2500 psi and 7 GPM.
He wants a 540 motor so a hyd motor with a cu in displacement of 3 cu in, would turn at 540
This us at no loss, so if you figured the loss from the pump to motor, the you would need more pump GPM.
Torque would be 3 cu in at 2500 psi = 1194 in lbs.
If you think 8 HP is enough, then 12HP is even better .
8 HP can do 6 GPM at 2000 psi.
This is not .000 accuracy, but close enough.
   / Need help on rotary broom hydraulic conversion #9
Charlynn Hydraulic Motor, Model 101-1008-009
This Charlynn motor is a 22 cu in at 1800 psi. Takes 12 GPM for a speed of 123 rpm.
That speed would be correct for a motor to drive the brush core directly,which all hydraulic powered brooms use.I don't want to drive the core bar directly as it would put the motor sticking out on the side of the broom.I want to mount it close to the lower sprocket drive shaft where it's better protected from being damaged.The original driveshaft at this location run at around 500rpm or so via the 4:1 reduction gearbox unit,which was driven by the 2000rpm front pto.The chain/sprocket drive on this broom reduces the 540 rpm to right around 135rpm(max) to the brush core shaft.
I received an email back from sweepster today.They had no idea what the in lb torque requirement would be to run the chain drive loop.Just for fun,I put a 7/8 socket on my little 12v master mechanic cordless drill,set it on the hex shaft and lowered the broom to the proper brush pattern.Don't know what the rpm was ,but was enough power to probably sweep the garage floor.Then I hooked up my honkin cheap harbor freight 1/2" low speed drill to it.I think I could lower it in the back yard and throw turf over the fence and dig a hole with it.Neither one of these drills have in/lbs torque ratings.
So,I have a pretty $800 boat anchor at this point. Thanks to all for trying to help.Maybe I can find a solution.
FYI,the Char Lynn 1002 motor that was used in the calcs that the surplus center tech used was given by me,as that is the motor used in the small picture above.I lifted that pic from a thread at WFM and that was the model number stated.He said there were no numbers on the pump.
   / Need help on rotary broom hydraulic conversion #11
I forgot to look at that motor today to find out just what it is. The # I posted I said that was what I though it was with out checking. That # might not even be close, right now all I know is that it's off a broom and was chain drive.
   / Need help on rotary broom hydraulic conversion #12
So, lets's start from the broom and work back to the front PTO to get the components you need.
What turns the broom? A gear?
   / Need help on rotary broom hydraulic conversion #13
And you want a hydraulic motor to turn that gear at 540 RPM?
Given the info you gave us, that the brush could be turned by 8hp and that it easily can be turned with a large drill....
And given the pumps and motors formulas at Surplus Center
where 1hp = 1 gpm X 1500psi, and 2gpm @ 1500 psi = 2hp, (linear relationship)
Surplus Center
Lets plug in the numbers.
SOMEONE CORRECT ME IF THIS ISN'T RIGHT! Math is not my strong suit! :)
8hp=8gpm @ 1500psi.
540rpm = 231 x gpm / motor displacement.
540rpm = 231 x 8gpm / motor displacement.
540 = 1848 / motor displacement.
1848 / 540 = motor displacement.
1848 / 540 = 3.42 cubic inch motor
So you need a motor that is 3.42 cubic inches and is rated for 8gpm @ at least 1500psi
and
you need a pump will supply 8gpm @ 1500psi when turned at 2000 rpms (the speed of your front PTO that you want to mount the pump to).
Does that sound correct?
A 48T sprocket chained to a 12T sprocket as shown in the first post. The speed flow backwards would theoretically be 135 on the core bar,540 at the 12T sprocket shaft,then 2160 from the tractor pto.These figures are at WOT of 3600rpm. Basically,the core is driven by two 4:1 reduction drives,one being the gearbox and the other being the chain loop.
BTW,here's a pic of that stacked gearbox that went south on me.It's actually two right angle drives running 2:1 reduction on each box.They're connected by a common shaft so they can swivel with the swivel hitch frame of the broom.The top box has a torque limiter bracket attached to the channel upright where the chains are held to lift/suspend the broom.
   / Need help on rotary broom hydraulic conversion #15
Good picture! :thumbsup:
So you want to turn that little gear shaft at about 540rpm correct?
   / Need help on rotary broom hydraulic conversion #17
You know you can run a hyd motor at a 1 : 1 ratio at 540 rpm with the motor on top of the frame and to the inside. Not sticking out the side.
A hyd motor can turn in both directions.
That's what I was thinking also,instead of making a bracket and running 2 sprockets and chain.If I fab that myself without welding I'd use two muffler clamps on the pivot bar,a short piece of 4 x 4 angle iron(or larger),drill the appropriate holes in it and use some sort of short coupler.
Yes , I plan on having a reverse feature to run the broom backwards.From what I've read that's a very handy thing to have.Just have to figure out the pump,motor thing first.
I did some reading last nite on hyd/drive tillers,which I would think would use a lot more power to turn than this broom.Several JD garden tractors, similar size wise to my tractor, that use a pump attached under the tractor and fitted to the mower deck PTO 2000rpm drive.No one complained for a lack of power to run the tillers.
   / Need help on rotary broom hydraulic conversion #19
Have you started pricing all this stuff?
You're looking at $700 if you buy new.
You don't get very much snow down there. Is it worth it VS a plow that you can find for a couple hundred used?
Also, they still got that tree in the tower in town? :)
I wouldn't mind spending the money if I knew it would work properly.Right now I've got 7-800 invested in an attachment that's useless.I'm not going to scrap it or park it in a corner and hope a magic part comes along to fix it. I already have a plow,but I think a broom would work better on the sidewalks(no blade jamming). Yes,that tree is still up there.It gets plenty of water from the spring in the clock....:laughing:
2017 Case CX145D (A60462)
2017 Case CX145D...
2017 VOLVO SD45B PADFOOT ROLLER (A60429)
2017 VOLVO SD45B...
2005 Jeep Patriot SUV (A59231)
2005 Jeep Patriot...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Metal Transport Rack (A59228)
Metal Transport...
Amada M-3060 Mechanical Metal Shear (Japan) (A59213)
Amada M-3060...
