Injector Cleaners
   / Injector Cleaners #1
1Lawman
Joaquin, TX
2012 John Deere 5093E
I have a 2012 JD 5093E..I bought it a couple of months ago with 64 hours on it..I believe the person that had it before me may have allowed it to idle a lot..It produces black smoke more than it should..My dealer cannot find anything wrong with it..I would like to get the best injector cleaner available to run through it...Will that help?
Looking for comments and suggestions..
Thanks
   / Injector Cleaners #2
not unless you run it "straight" liqui-moly diesel purge .... mixing it in a tank just dilutes the cleaning effect.
a can of it will clean any injector system ( pump and injectors )
if you really want them "clean and spraying properly" pull the injectors and have a shop clean , adjust and pop test to get them all the same ....
   / Injector Cleaners #3
Just buy the injector cleaner from Deere next time you go in the dealership. That way you can say you tried it and if it doesn't work they can't come back and blame it on that. Deere usually has good stuff, their ethanol treatment is very superior to anything else I've used. Glass cleaner is the best too, my girlfriend prefers that over anything she can buy in the store.
   / Injector Cleaners
Think I'll try both! thanks
   / Injector Cleaners #5
Hiya,
Dirty injectors are only one possibility for excessive black smoke in a Diesel. Other possibilities are clogged air filter restricting flow, low engine temp from a faulty thermostat, restricted/damaged intercooler, turbocharger issues (low RPM or issues in a variable geometry type), common rail mis-adjustment keeping the injector open too long, over-fuel adjustment on the pump, low quality or aged fuel.
Remember some smoking when the throttle is opened quickly or in high load situations is normal but you shouldn't be "rollin' coal"
My 2 cents,
Tom
   / Injector Cleaners
Hiya,
My 2 cents,
Tom
Tom,
You summarize very nicely what I've learned in my research of this problem..The tractor is still at the dealer and has been checked by them..The service manager seemed to agree that it was smoking more than it should but said they could find no problem..He said the fuel injector timing was within spec and explained there was a 4 degree window for that spec and that they did adjust it slightly..I checked the tractor yesterday and it still seems to smoke excessively in my opinion...The service manager said that some just smoke more than others..The tractor is a 2012 model with only 80 hours on it..I bought it a month or two ago with 64 hours..The man that owned it before me mentioned to me that much of the time the tractor was just idling so I just don't know what else the problem could be.. I looked at another 2012 5093E that belongs to someone I know and it too seemed to smoke quite a bit but not as much as mine..I also spoke to someone over the phone who said that his too smoked "a little"..
   / Injector Cleaners #7
When you say smoke, does it smoke at no load or under load?
The best thing to do is get a good fuel conditioner from Deere and run it hard under high load. An engine that has idled a lot will smoke heavy under load for a while till it burns out the carbon build up. I find it hard to believe that any damage was done in 64 hours.
   / Injector Cleaners #8
Here is a write-up on JD conditioners:
Fuel-Protect Diesel Fuel Conditioner, Summer Formula
(TY26784, TY26785, TY26786)
Features and benefits
Boosts Cetane Number for faster, smoother, fuel efficient starting
Aggressive Detergents and dispersants clean and keep clean injectors helps prevent injector erosion, prevents emissions deterioration due to deposits, and cleans entire fuel system
Lubricity Improver for added protection and reduced fuel injection and pump wear when using Ultra Low Sulfur Diesel (ULSD) fuel
Moisture Control improves water tolerance and helps minimize microbial growth
Maintains fuel pump warranty
Minimizes smoking
Compatible with all diesel fuels
Fuel-Protect Diesel Fuel Conditioner, Winter Formula
(TY26787, TY26788, TY26789)
Lowers Cold Filter Plugging Point (CFPP) and Pour Point improving cold weather fuel flow
Extends fuel filter life
Minimizes smoking
   / Injector Cleaners #9
Does it still have fuel in it from when you bought it?
Fill it with fresh fuel with the treatments mentioned and run the SNOT out of it. Go plow up something or find some tractor tall grass to cut wet or something and put a load on it.
The tractor isn't even broken in yet.
   / Injector Cleaners #10
Load it up heavy as you can and run it for several hours so the internals get very hot and that will burn the carbon off. I have seen AG tractors running at night under heavy load and you can see the exhaust manifold glowing along with the exhaust pipe. NO CARBON BUILD UP THERE.
2005 Sterling Acterra Tender Truck (A51039)
2005 Sterling...
2000 MACK RD688 TRI AXLE DUMP  TRUCK (A51222)
2000 MACK RD688...
2018 International WorkStar 7400 T/A Dump Truck (A50323)
2018 International...
GENERAC MAGNUM LIGTH PLANT (A50854)
GENERAC MAGNUM...
2006 Toyota Tundra 4x4 Crew Cab Pickup Truck (A50323)
2006 Toyota Tundra...
2019-2024 Dodge Ram Front Bumper (A49461)
2019-2024 Dodge...
