mamafudge
   / mamafudge
You need to tell us more about the nature of the problem in order to get any useful advice.
Steve
No power to lights, instruments, or starter. Started to repair by replacing battery.checked fuses appear good. wires look connected. There is a wagner dot fuse about the size of a ping pong ball.i dont know what it does or if it is good.
   / mamafudge #5
Dd you remove both ends of both battery cables and clean them bright? Often guys get enough juice to start but when they replace the batt the cable gets moved enough to break contact. Or, maybe an instrument panel ground?
Jim
   / mamafudge #6
Clean & tighten all 4 battery cable connections.
   / mamafudge
Jim
Thanks Jim I will check both. Instrument ground sounds possible
   / mamafudge
Ah. Didn't check other ends. Might be right. Makes sense. Thanks
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A52377)
2013 Chevrolet...
2017 John Deere HPX615E 4x4 Utility Cart (A51691)
2017 John Deere...
UNUSED RAYTREE RMBD72-72" DRUM MULCHER (A51248)
UNUSED RAYTREE...
40' High Cube Multi-Door Container (A50123)
40' High Cube...
2015 TAKEUCHI TB290 EXCAVATOR (A51246)
2015 TAKEUCHI...
Bobcat 14in. Excavator Bucket (A53117)
Bobcat 14in...
