mamafudge
   / mamafudge
You need to tell us more about the nature of the problem in order to get any useful advice.
Steve
No power to lights, instruments, or starter. Started to repair by replacing battery.checked fuses appear good. wires look connected. There is a wagner dot fuse about the size of a ping pong ball.i dont know what it does or if it is good.
   / mamafudge #5
Dd you remove both ends of both battery cables and clean them bright? Often guys get enough juice to start but when they replace the batt the cable gets moved enough to break contact. Or, maybe an instrument panel ground?
Jim
   / mamafudge #6
Clean & tighten all 4 battery cable connections.
   / mamafudge
Jim
Thanks Jim I will check both. Instrument ground sounds possible
   / mamafudge
Ah. Didn't check other ends. Might be right. Makes sense. Thanks
2010 Autocar Xpeditor T/A Labrie Side Loader Garbage Truck (A51692)
2010 Autocar...
Deutz 2WD 53HP Utility Tractor (A51691)
Deutz 2WD 53HP...
UNUSED LANDHERO LDHGAC40V AIR COMPRESSOR (A51248)
UNUSED LANDHERO...
2025 CFG Industrial MX15RX (A50123)
2025 CFG...
GENERAL ELECTRIC DEEP FILL ELECTRIC WASHER (A51248)
GENERAL ELECTRIC...
CABINET OF HOSE ENDS (A53843)
CABINET OF HOSE...
