mamafudge
   / mamafudge
You need to tell us more about the nature of the problem in order to get any useful advice.
Steve
No power to lights, instruments, or starter. Started to repair by replacing battery.checked fuses appear good. wires look connected. There is a wagner dot fuse about the size of a ping pong ball.i dont know what it does or if it is good.
   / mamafudge #5
Dd you remove both ends of both battery cables and clean them bright? Often guys get enough juice to start but when they replace the batt the cable gets moved enough to break contact. Or, maybe an instrument panel ground?
Jim
   / mamafudge #6
Clean & tighten all 4 battery cable connections.
   / mamafudge
Jim
Thanks Jim I will check both. Instrument ground sounds possible
   / mamafudge
Ah. Didn't check other ends. Might be right. Makes sense. Thanks
KSI Conveyor (A53473)
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A51691)
2016 Godwin CD150M...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A51692)
2003 Pierce Tilt...
PAIR OF FRAME MOUNTS FOR VACUUM PUMPS (A53843)
PAIR OF FRAME...
UNUSED FUTURE D45 HYD POST DRIVER (A51248)
UNUSED FUTURE D45...
2017 Bobcat E20 Excavator (A52384)
2017 Bobcat E20...
