Heres things the kioti wouldnt do that the kubota can
   / Heres things the kioti wouldnt do that the kubota can #1
landedakioti
Gold Member
vermont
kubota L4060 hst
   / Heres things the kioti wouldnt do that the kubota can #2
Quite a project,I would turn around and drag that big boulder from the back of the tractor.Tough on the FEL the way you are doing it.
Is the L4060 the replacement for the L3940?A friend has the L3940,he is a tinkerer so he "turbo-charged" it.
   / Heres things the kioti wouldnt do that the kubota can #3
Just curious about the thread title. Why would the Kioti not perform these tasks?
   / Heres things the kioti wouldnt do that the kubota can #4
Can't see how brand would matter if the tractors were equals.
The kioti wouldn't start and when it did run it would die out . If I tried to back drag it would die out . I would have to shovel gravel into the bucket then dump it.
   / Heres things the kioti wouldnt do that the kubota can #7
If memory serves me correctly, often not the case, landedakioti got a lemon and was finally able to return it to Kioti and get the Kubota. I have Kubotas and my brother has a Kioti, both companies make good tractors.
Landedakioti, I'm glad to see you wound up with a tractor that works well for you.
   / Heres things the kioti wouldnt do that the kubota can #8
Just post your projects and pictures, they are quite interesting. You don't have to keep bashing Kioti - we've already heard all about the lemon you got. Let it go already.
Wasn't bashing . I wish that one worked like a tractor should have. It is what it is. I did like the design of the kioti.
If memory serves me correctly, often not the case, landedakioti got a lemon and was finally able to return it to Kioti and get the Kubota. I have Kubotas and my brother has a Kioti, both companies make good tractors. Landedakioti, I'm glad to see you wound up with a tractor that works well for you.
Thank I'm glad to . I wished it worked out . Every brand gets a few lemons it's how the other brands held it. I had a couple small things with the kubota and the dealer came out fixed it . Some fitting weren't seated right and from factor some hoses where over crimped and leaking . Fix right away. Didn't have to fight with them like kioti dealer
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
Agrotk 72" Skid Steer Broom, New  (A52384)
Agrotk 72" Skid...
CATERPILLAR VC60DSA SHOP FORKLIFT (A52472)
CATERPILLAR...
2020 Peterbilt 520 Truck (A51692)
2020 Peterbilt 520...
2018 Infiniti Q50 AWD Sedan (A51694)
2018 Infiniti Q50...
7046 (A50322)
7046 (A50322)
