Is it possible to lengthen PTO/driveshaft??
   / Is it possible to lengthen PTO/driveshaft?? #1
Garycw
Oh-Ky-Fla
JD 1025R w/ fel, Farm Pro 2425, ford 841 & 851
I have a older 3pt. seeder/ spreader that has a short square tube drive shaft. I have a tractor it will barely work on but I'm wanting to use on another tractor. The shaft is about 8-10" too short to go on PTO spline. Wondering if there's a simple solution to extend the length of shaft or PTO ?
   / Is it possible to lengthen PTO/driveshaft?? #2
I guess it could be done by replacing shaft with longer one but these light duty shafts are not that expensive. can get new everything for around 100 dollars or less.
Thanks. I guess I'll just have to use it on the tractor it works on. Since the spreader was light, I thought I'd put on a compact tractor.
I'll check out the extender. I looked at the spreader PTO shafts at tsc, but my sor rated doesn't have a spline. It bolts to spreader with two bolts.
   / Is it possible to lengthen PTO/driveshaft?? #6
Square & rectangular telescoping pto shafts are easy to lengthen/shorten. I've done that task several times. One must remember to keep u-joints in time(phase) but no balancing is required.Just cut female section off with a chop saw and insert a piece of rd tubing. BTDT
On telescoping shaft I could shorten easily. However this is a solid one piece shaft. It's about 1 1/2" square tube. Splined on one end for tractor & a flat plate that bolts to spreader
   / Is it possible to lengthen PTO/driveshaft?? #8
I had my PTO shaft extended. The welding shop WOULD NOT extend it by welding on additional shaft lengths. They put a new shaft on each end. The owner told me - too much liability when welding on add shaft length. A new PTO shaft was $264 - having it reworked was $100.
   / Is it possible to lengthen PTO/driveshaft?? #9
On drive shafts I worked on the female inside square was only about 6"s long the rest was just plain old round tube. Plus 540 rpm isn't going to GRENADE if a competent welder does the welding.
   / Is it possible to lengthen PTO/driveshaft?? #10
Machine shop should do it. Locally we have a shop that does driveshaft work that will also work on these.
TX Jim, I have found the same. Only the last 6"'s is square.
2012 PROCO 130BBL VACUUM TRAILER (A53843)
2012 PROCO 130BBL...
2012 CATERPILLAR 279C2 SKID STEER (A51242)
2012 CATERPILLAR...
2012 Infiniti G25 Sedan (A53424)
2012 Infiniti G25...
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A55301)
2012 KINZE FLAT...
UNUSED X-STAR 101" X 20' LOADING RAMP (A51247)
UNUSED X-STAR 101"...
2024 KMC 7406 LOT NUMBER 11 (A53084)
2024 KMC 7406 LOT...
